Where to buy replacement key
My key to the RX has been breaking apart and I need to order a new one. Can someone tell me where I can order the key precut, so I can just program it on my own?
Thanks!
Thanks!
I only have one key and need to get a new key as well.
I went to Lexus and they want $230 to cut and program the key...
As far as I know, you can't program RX330 or 350 key... only dealer can do that.
Does anyone know any other way to save $ on key replacement?
They key is really three pieces.
Half shell
blade+other half shell
Electronics.
If the plastic half shell is broken, there is a good chance that the dealer would give you the part for free.
If the blade+other half shell is broken you have to buy a new key-blank.
If the electronics is broken/lost then you need to order the whole key [master or valet]
To purchase you have the dealer (will give you genuine keys) or you can explore the after market. There are different quality levels when you talk about after-market product.
If you buy after market make sure the key is uncut or some one will will cut the key for you. [requires special equipment ... dealer has it]. Dealar may refuse to cut a blank key if they think the key blank is not genuine and it can damage there equipment {may or may not be true}. Some sellers will cut the key if you send them the 4 digit code stamped on your emergency key card. Dealer can look up the vin.
If you have at least one master key, the new key remote can be programmed. Steps have been posted in CL (please check if they will work for 330/350. Dealer can program the remote and so can some of the after-market sellers. [They may require you send them the master key]
Key balnks range from $30's (after market) to $80's. Cost to cut the key is about $20. Genuine complete key can run you close to $300. All of these are approximate prices.
Salim
Half shell
Electronics.
Salim
MultiTasking Mom
the shell on my key broke recently after 4 years. the plastic cracked at the base where the shell meets the blade. the transponder was fine, so all i had to do was order the shell w/ new blade (the blade cannot be transferred; it's "fixed" to the shell).
as always, i contacted lexus-parts.com and the shell, with a CUT blade for my car, is about $53 after the 10% CL discount. just provide them with VIN and proof of ownership and you are all set.
the key arrives within a week and you just move the transponder over to the new shell. now i have a fresh new key
Salim
