tilt wheel connector
Old 02-21-17, 09:52 PM
aschulz261
aschulz261's Avatar
Default tilt wheel connector
Can anyone point me in the right direction to find the connector for the tilt and telescope feature of the steering wheel? I have to use hand controls to drive and the "certified" installer decided the placement of the wheel and then disabled that function.
I have been to my local dealer to see if they can rectify the situation and was told that they won't touch the hand controls, but, if I have them removed, they will look at the problem. I had to shake my head when I told them that if I had them removed, I can't drive the car.
This is so frustrating. It's 2 bolts to drop the controls from the column, but I need to know where to look from there. Can anyone help?
The wheel still moves when the car is started, so I don't think the installer actually broke anything. I HOPE they just disabled the button on the side of the column.
Old 02-22-17, 05:27 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
Disabling the switch would set DTCs and you would see something on the dash indicating a failure. The switch itself talks to the Tilt & Telescopic ECU - it has its own computer - through two wires with varying resistance depending on which way you move it.
propcop
01-24-16 03:46 PM
Sentinel
04-24-11 08:02 AM
wagomaniac
SC- 1st Gen (1992-2000)
11-30-08 07:42 PM
GSTRANCE
06-13-02 11:24 PM
Quick Reply: tilt wheel connector
