Door Dome Light/Cluster Light on.. Doors are closed though?
Super Moderator
ok .. rig something on those door panel lights just to see if they are lit or not with a door open and close so you don't waste your time and money replacing door actuator assembly if not necessary.
Technical Information System (TIS) of Toyota has all the info you want about your Toyota / Lexus / Scion .
On this thread , I have posted the wiring diagrams of the older SCs starting at post #83 https://www.clublexus.com/forums/per...de-easy-6.html
Check Diagram 8 and its follow through diagram which is Diagram 7 .. you will find those door open detectors and how they go to the integration relay .
Deegee (01-04-17)
Here is what I've come up with after awaiting for the parts to come in.
The driver side door light doesn't turn OFF if both doors are firmly closed. The passenger side light turns OFF when the doors are closed.
Sounds like the driver side door actuator is the culprit here. Thanks for all the help Gerrb!
