LS1 Swap?
Old 12-30-14, 02:26 PM
Mastana
Mastana's Avatar
Default LS1 Swap?
Hey has anyone ever done a LS1 swap here?
Old 12-30-14, 05:38 PM
turbodremz
turbodremz's Avatar
Myself, fried_rice, Millertime, Evan@D3PE (forgot his username here), and about 3 or 4 other people.
Old 12-31-14, 09:55 AM
JE
Former Sponsor
JE's Avatar
We just finished one up for a customer. World renowned LS kit manufacturer Sikky just wrapped up their kit. We tested one of the first production setups. Bolts right in like OEM. I know it's not up on the site yet but I heard they are taking pre orders. The design concept is similar to their other kits where it comes with an oil pan designed specifically for fitting the SC300/400 IS 300 etc. Motor mounts, trans mounts and headers, even clutch master cylinder and power steering line kits. Everything fit so well be basically did the swap in one day. Makes it easy for the backyard DIY guy cause there is absolutely no fab needed. You can see some of their other kits at www.sikky.com
Old 12-31-14, 07:54 PM
Mastana
Mastana's Avatar
Wow, sounds like it was easy. It was a LS1 ? What kind of tranny did he have on it?
Old 01-02-15, 05:25 AM
JE
Former Sponsor
JE's Avatar
We sourced him a complete drop out from a 2000 camaro that was hit in the rear. So engine, trans, ecu etc....That car comes with the T56 6speed.
Yeah, with this kit it is super easy. Thats the way Sikky designs there stuff so it is bolt in friendly and a backyard mechanic can do the install without headache.
Old 01-02-15, 09:56 AM
turbodude
turbodude's Avatar
I sold this guy the 4.8 thats in his sc300. It was out of an 06 1500 if I remember right. Pretty budget swap if you arent looking for a full blown LSx.
That particular 4.8 had the ls6 casting heads on it. I had ls6 vavle springs put in it and the later model z06 cam.
Hes also got a 4l80 auto behind it. Makes good power for 12psi. Sure its a blast to drive.
Old 11-25-15, 03:16 PM
maxgee
maxgee's Avatar
Default Ls3 on boost in SC400
Corvette cluster also installed along with ls3 and 6l80e trans.
https://instagram.com/p/77E8M7Hf3J/
DatMoFo
SC- 1st Gen (1992-2000)
20
07-12-16 05:38 PM
lawlexus08
08-14-15 07:39 PM
RotaSpinna
SC400 / 300 Classifieds
05-04-15 07:01 AM
looneytune
22
04-30-13 11:06 AM
DslDrager
Performance
06-02-11 02:39 PM
Quick Reply: LS1 Swap?
