will a chaser r154 fit into a sc300 with no modification to the shifter. I believe they are the same but i want to see if anyone has used one, also will the driveshaft bolt up?
will a chaser front clip work in a sc300? what mods will be needed?
chaser r154 will fit PERFECTLY. and yes, a chasers body plugs are very similar to the soarer. so extend the hardess i believe its only a couple wires you might have to repin.
No the chaser body plugs are completely different from the Soarer i had a Soarer 1JZ before and i couldn't make it work on my SC had to send the Harness out to Tweak.
^ Its a 5 speed tranny I didnt think it needed any plugs? well besides reverse wire and mabe speed sensor, but sc's speed sensors are on the wheels separate from trans.
I believe he was referring to the body harness.
Yes the trans will work. The harness will not work unless its sent out.
