Tail light warning still ON even after replacing the bulb(97 SC300)
Old 05-13-09, 12:02 AM
lowkeySC
lowkeySC's Avatar
mine just did this tonight. i also used autozone bulbs. and it has nothing to do with the spoiler light not working. i have a 97 and when my spoiler light wasnt working my warning light didnt go on untill one of my rear parking light bulbs blew out.
Old 05-13-09, 12:21 AM
turbodremz
turbodremz's Avatar
mine did this for 2 days...i pulled the negative side off the battery for a couple minutes, and its fine now.
Old 03-12-16, 04:45 PM
trd24mr2
trd24mr2's Avatar
So my indicator lit up so I replaced both tailight bulbs (come in pairs) and they worked fine. But when I turn on my headlights, everything works fine but the indicator still lights up. Does anyone think pulling the battery would work?
Old 11-19-16, 04:15 PM
BlackIRON
BlackIRON's Avatar
i had the problem only hen i would turn the lights on and first hit the brakes, i replaced all the bulbs and the problem persisted, i ended up taking out the LED from the cluster.
Old 11-19-16, 06:26 PM
t2d2
t2d2's Avatar
You might have the wrong 3rd brake light / lamp failure module combo. The module is different depending on whether the car came with the 3rd brake light in the spoiler or on the parcel shelf. The dash warning light will come on when you first hit the brakes if you have the wrong combo.
Old 11-19-16, 08:01 PM
BlackIRON
BlackIRON's Avatar
i received the car with no spoiler brake light and just the normal non brake light speaker cover, when i went to install said speaker cover that has the brake light i could'nt find the plug in for it anywhere so i am still stumped on it. Do all of our cars support the interior brake light?
Old 11-19-16, 08:32 PM
t2d2
t2d2's Avatar
That I'm not sure. Non-spoiler cars have the spoiler wiring wrapped up above the right trunk arm, but I'm unaware of whether the opposite holds true. The parcel shelf wiring should be pretty obvious if it's there, being part of the subwoofer bundle.
No spoiler brake light and no parcel shelf brake light...so, the car came without a 3rd brake light? It seems less likely that someone sourced a non-brake subwoofer cover to delete the parcel shelf brake light than it is they went with a wingless trunk and didn't think to add in the interior light.
Old 11-19-16, 09:28 PM
BlackIRON
BlackIRON's Avatar
So pretty much its a 99 with the full body kit including the small spoiler that doesnt have the brake light. Tomorrow ima take another feel behind the sub.
Old 11-19-16, 10:23 PM
JiHoonie
JiHoonie's Avatar
I thought that the 97+ all have the 3rd brake light in the spoiler. Perhaps a previous owner swapped the 99 wing to a 95-96. Pull back the trunk lining on the lid and see if you have a wiring running up the right-middle of it.
Old 11-19-16, 10:58 PM
t2d2
t2d2's Avatar
I've never heard of a stock spoiler without the brake light. Is it an aftermarket body kit?
Old 11-20-16, 12:41 AM
BlackIRON
BlackIRON's Avatar
the car does have the wiring running up the right middle of the trunk ,i have a spoiler that does have a brake light off of a 97, ima swap them tommorow and see. the one on there now is the little 96 tail/spoiler but it seems to have been sealed and painter over where the third light is lol. I also assume the reason i dont have the wiring for the subwoofer light is because i have that trunk wiring?
Old 11-20-16, 08:43 AM
t2d2
t2d2's Avatar
Well, given the handful of oddities you've got with your 3rd brake light(s), we can safely assume that's the source of your mystery dash warning light.
Not necessarily. All cars have the trunk wiring, but I'm unsure whether a car originally equipped with the spoiler has the parcel shelf wiring.
Old 11-27-16, 08:16 AM
kolessc400
kolessc400's Avatar
You have the wrong bulb In one of them if the resistance is off at all it will pop on... any front corner marker, tail lights, brake lights, plate lights or 3rd brake light if any are them wrong part number they may even look the same you can just walk in and grab the wrong one of your not careful so all your lights will work but the inductor will be on
2gsAlex
06-06-19 11:02 PM
caverman
09-21-17 03:21 PM
mate01
06-09-16 03:01 PM
GS400NYC
12-09-13 07:28 PM
mike.gani
Lighting
08-26-07 04:25 PM
Quick Reply: Tail light warning still ON even after replacing the bulb(97 SC300)
