Tail light warning still ON even after replacing the bulb(97 SC300)
The tail light warning was on so I replaced the bulb. It was the bulb that lights up when the gear is shifted to PARK position. New bulb works fine but the warning light is still on. I check all the bulbs including the brake lights and all seem to be working fine.
Are you positive it was the correct size bulb you put back in?
it happend to me once make sure the light work right if they are it could just be a lose connection in the clip from the wiring to the light... wait do you have the light that goes in the middle speaker grile ???
Originally Posted by YeA 2jZ
(Post 4480268)
do you have the spoilerless (wingless) trunk? |
Same issue I have. All bulbs light up fine and still get warning light..
HELP!!!! |
Originally Posted by Amini9
(Post 4480275)
yeah, that could be the problem.
Mine has this too. The Toyota tech said it was because I used an autozone bulb instead of an OEM toyota bulb. The ECU can tell the difference in the resistance...
mines did the same thing when i installed some autozone led bulbs but when i switched it back to the stock bulbs the light went away..i guess it's b/c of different watts output?
Originally Posted by babyduke
(Post 4480032)
I replaced the bulb. It was the bulb that lights up when the gear is shifted to PARK position. I check all the bulbs including the brake lights and all seem to be working fine.
Originally Posted by Bkjasonp
(Post 4480277)
HELP!!!! It was like 20~something for all of them i think |
(Post 4480275)
Originally Posted by INEEDANSC3
(Post 4480583)
If it is not on when you start the car then what triggers it??? if it comes on when you put your foot on the brake to shift out of park then its a brake light, check the center bulb(in the rear deck near sub). If it comes on with the lights then its a tail light bulb.
My tail light warning lamp comes on now, after replacing a license plate bulb with an autozone one. all my lights are working fine afaik.. 92 sc 300. wonder if i should try a different or oem bulb
Originally Posted by sc-driver
(Post 4480643)
Had the same problem. I just went to Wal-Mart and changed ALL the bulbs. The lil warning light never came back. :p
It was like 20~something for all of them i think Thanx:thumbup: |
just yank the stupid indicator bulb from behind the cluster :)
| All times are GMT -7. The time now is 10:24 PM. |
