Oil leak
Old 09-22-08, 08:30 PM
lemaylexus
lemaylexus's Avatar
Default Oil leak
I searched a little on here but couldn't find exactly the answer I was looking for. I found a small puddle of oil under the car tonight. Nothing too major, but it concerns me nonetheless. Can anyone tell me common locations for oil leaks on the 2JZ-GE's? I hope this isn't anything serious because I really can't afford it right now with the economy in its current state. I've lost a lot of money in the past 3 weeks.
Old 09-22-08, 08:34 PM
PecosBill
PecosBill's Avatar
I had the same thing when I first bought my car. My uncles works for Lexus and he said its a common thing in the SCs. I dont remember exactly what the problem, I think a gasket or something had to be replaced. It cost me about 250 to fix.
TheMole
TheMole's Avatar
Valve cover seal, oil filter housing, oil pan, front/rear main seals...
Old 09-22-08, 08:41 PM
93sc3005sp
93sc3005sp's Avatar
make sure its not the power steering because they tend to leak heavily on these cars if seals and hoses have not replaced, at least thats what mine did
Old 09-22-08, 09:39 PM
lemaylexus
lemaylexus's Avatar
Thanks for the quick responses. I was hoping this was gonna be something I could just do at home with some simple tools, but doesn't look like I'm gonna get off that easy.
Old 02-12-09, 07:18 PM
brian8886
brian8886's Avatar
what is the thing that you replace that cost $250 and then no more oil leak?
Old 02-12-09, 07:31 PM
StiCk3
StiCk3's Avatar
look under the distributor for oil. there should be a small shield underneath where oil comes out of the distributor seal. Also look into the valve cover gaskets. those two were the problem with me
Also Check the PCV valve to see if it's still working as a clogged PCV can cause seals to pop all over the place. to test it remove it from the valve cover and run compressed air through the inlet side. It should flow freely. After that run compressed air through the outlet side. No air should come out form there. If there is a prob with either side replace it.
Old 02-12-09, 09:04 PM
brian8886
brian8886's Avatar
Mine is leaking under the engine and on the oil pan cover. Does this has to do with PCV valve?
Old 02-12-09, 09:47 PM
1siksc
1siksc's Avatar
My oil pan drain plug had no gasket and that caused a pretty good leak, who would of thought.
Old 02-12-09, 11:55 PM
SCoupe
SCoupe's Avatar
Check the simple things first. Make sure that the oil filter is snug. I've had "leak" that was cured by another 1/4 ~ 1/2 turn on the filter.
Old 02-13-09, 12:02 AM
soarer13oy
soarer13oy's Avatar
My car leaks also. The bottom block looks really oily. Just too lazy to operate on the car lol. Im planning a swap within the next year so ill let it leak for now lol.
Old 04-18-09, 03:38 PM
sshahen
sshahen's Avatar
yea me too just yesterday i seen that my car was leaking from the rear main seal is there anything that i can do to stop it.
Old 04-18-09, 05:24 PM
LMoney4o8
LMoney4o8's Avatar
I just got back from finally fixing my oil leak. The problem was the valve cover gasket and I think the oil filter housing.
Old 11-22-10, 08:01 PM
jkenciso
jkenciso's Avatar
my gs300 started to leak from the oil filter housing. is it a gasket or seal and where can i buy it from?
SpencerT
08-12-12 11:08 PM
GS300 I6
GS - 1st Gen (1993-1997)
03-07-10 11:40 PM
0nePutt
Maintenance
10-25-09 02:17 AM
jgrill5
01-04-06 11:10 AM
indypwr
22
03-16-03 07:35 PM
Quick Reply: Oil leak
