Rebuilding 2jz-ge "feel free for any input"
Old 08-15-08, 01:12 AM
tcd300
tcd300's Avatar
Default Rebuilding 2jz-ge "feel free for any input"
REBUILD: 2jz-GE
ARP head studs $139.86 rod bolt - $64.75 main studs $119.37
Bearings - acl race bearings - $230.00 stock size
seals/gasket kit GTE - $212.99
damper pulley - ATi- $407.60
Headgasket GTE- SCE Head Gaskets .062inch -$117.37
Pistons GTE - JE $641.99
Piston Rings GTE - Total Seal Piston Rings $257.37
Rod GTE - Eagle Rods $495.00
Valves GTE - Ferrea Valves "stock size" $263.40
Valves Springs GTE - Ferrea $351.20
Valve Locks GTE -Ferrea $4.68 comes in 2
Valve Spring Seat Locators GTE -Ferrea $92.96
Valve Retainers GTE - Ferrea $202.80
Valve Guides GTE - Ferrea $113.52 "exhaust side" / $98.40 "intake side"
Total - $3,873 "rounded" not including shipping
Machine work:
mill the head-this takes off a very thin amount of metal to make a perfectly flat mating surface
deck the block-same thing as milling the head just to the block
cylinder hone-removes unmeasurable amount of metal from the cylinder bore to make a new surface for the new rings
wash or acid bath if available-cleans and degrease engine completely, removes corrosion and oxidation from the aluminum
Total - $1,300
Old 08-16-08, 09:54 AM
cbrasian
cbrasian's Avatar
sounds more like your gonn build the motor..... than rebuilding it with the valves etc.... the price is really good for what your getting
Old 08-17-08, 01:56 AM
tcd300
tcd300's Avatar
thanks i try to keep it at a minimum lol =]
Old 08-17-08, 01:18 PM
soarer479
soarer479's Avatar
what are your power goals? id recommend having the crank checked and knife edged if needed. also if your going for big power id suggest doing billet main caps check out a company called pro gram for the mains
Old 08-17-08, 01:41 PM
YeA 2jZ
YeA 2jZ's Avatar
wow sounds like your gonna be making some big numbers... GL
Old 08-17-08, 08:31 PM
tcd300
tcd300's Avatar
thanks =] i try my best my power goal is max hp i can get out of this set up hehe
Old 08-17-08, 10:56 PM
5sp_jzz30
5sp_jzz30's Avatar
seems like a dyno queen build in progress. enjoy...
Old 08-18-08, 03:09 PM
soarer479
soarer479's Avatar
well like i said before dont leave out the mains while you have the motor apart its worth it
Old 08-18-08, 11:51 PM
xx69xx
xx69xx's Avatar
You speak the troof.
Old 08-19-08, 12:39 AM
evileagle
evileagle's Avatar
If your power goals are anything less than 600whp why wouldn't u just get a BRAND NEW GTE shortblock from toyota for $2250? U know it will be assembled correctly and saves u the hassle of machine work etc...At least thats what i decided to do and Im gonna start this weekend!
Old 08-20-08, 10:14 PM
tcd300
tcd300's Avatar
GE block ownsss thats why =]
grumpi300
23
12-06-15 02:27 AM
BoostinAWD
03-05-15 01:58 PM
TLDriver
01-10-11 12:04 PM
adamgamz
Performance
06-09-08 04:54 AM
MIC123321
GS - 1st Gen (1993-1997)
11-06-06 08:37 PM
Quick Reply: Rebuilding 2jz-ge "feel free for any input"
