Gas Smell in Garage.....
Hey, just wondering if anyone knows why my '95 SC400 would be venting gas vapor after it's stopped. I thought it was supposed to depressurize as it went or something. The new loaners never do this. Could it be something just plugged up?
If I pop my gas cap open you can hear it woosh out.
Thanks,
Jason
Thanks,
Jason
Re: Gas Smell in Garage.....
Thanks,
Jason
Thanks,
Jason
Well it's definitely coming from the gas cap area. After I park the car when I get home, you can hear a very faint sssss sound. It appears to be venting from the cap, although it's very very slow. Over a bit of time though, I can walk out to the garage & smell the gas. There isn't much in the garage other than some tools or the car & I don't smell it whenever the car isn't there, or if I've vented the car & let the garage air out for a few.
Perhaps it's something dumb like the gas cap?
I fixed that venting hose a while back, as mine was dangling loose & the fumes were venting into the trunk then to the cabin. Now it's just into the garage.
Thanks!
~Jason
Thanks!
~Jason
get a new cap.
Inspect your current gas cap and see if it looks damaged anywhere around where it seals. If you suspect it may be damaged replace it asap, a cheap and quick fix if that's your problem. Get it from the dealer to ensure it seals properly, it's like $20. If that's a bit too much then get one from a chain stores like Kragen or PepBoys.
