adjusting SCxxx headlights
adjusting headlights
when i changed recently changed my low beam bulbs to piaa i noticed that the bubble was not level its pointed too low and is not aligned correctly. i tried adjusting it using a socket wrench 10mm to adjust the hight turned it clocked wise for few min bubble didn't move then tried counter clock wise the bubble did not move either. so i thought the bubble leveling thing is broken so i i tried adjusting without using the bubble. and turned the head light on and pointing it against the wall. then i tried turning the **** again clockwise and counter clockwise I didn't notice ne movement in the light. . i found this picture while doing a search.i tried turning both ****. dont mind the green.... does ne one have a picture of with the headlight attached point me to the right direction..... i would take a pic but i don't have a digi cam.
Screw A is for the vertical adjustment and screw B is for the horizontal adjustment. Make sure you're looking at the correct bubble. There are two, one for the high beam and one for the low beam.
George
George
George
George
p.s is there a better way to get to the adjustment without removing the battery.
Ok, here are links to the two pages that describe the adjustments. Maybe these will help.
All of the screws have 8mm hex heads so you may be able to use an open end wrench or socket to turn them without removing the battery. It will help to have small hands!
George
https://www.clublexus.com/gallery/sh...cat=500&page=1
George
hey thanks george. i just aligned it correctly. i got one more problem after aligning the headlights i noticed that my right seems a lot brighter than my left. do u know what could be the problem? bad connection that the metal aren't touching properly or is it my battery? i don't think its the battery cuz both headlight would be dim but its only the left one dim....
i didnt' really notice it b4 cuz i was mostly in the city there was alot of street light . now that i'm in buffalo where theres hardly ne street light thats when i noticed it.
This seems lke the most appropriate place to ask ..
For left to right adjustment by "B" in picture above ..
There is white plastic ****/nut on the same shaft as th 8mm head. [same shaft towards the lamp].
If I twirl the plastic ****/nut the white colored marker wheel moves quite rapidly inside the clear-tube (cylender). This moves the adjustment marks very quickly but there is absolutely no tesion (no feeling of actually moving the lamp .. seemsas if I am moving the marker only). On the other hand if I twirl the 8mm bolt-head I do feel the tension but the marker does not move even after number of turns.
The questions are:
What is that white plastic **** for?
Where and how do I set the adjustment for the white **** .. it does change the reference cylender.
Is the actual adjustment done by the 8mm head.
Does the 8mm head have to be spun a lot of turns before seeing actual shift. [If so i will adjust the position by the 8mm head by focusing on the wall and then use the white plastic **** to bring back the scale to normal.. reverse process]
Salim
The questions are:
Salim
JCtx
RC F (2015-present)
07-21-18 10:35 AM
