1991 lexus ls400 starting issues
Old 08-18-14, 02:47 PM
ladytj318
ladytj318's Avatar
Default 1991 lexus ls400 starting issues
ok hello im alittle new to this so please forgive me if i make any mistakes,
i was given a 1991 lexus ls400 its in great condition as far as exterior/interior but i cant seem to get it to start or turn over all the lights, bells, whistles, etc work but when i turn the key nothing happens
can anyone give me an idea where to start other then the starter,(been there done that)
thanks tracey
Old 08-18-14, 02:56 PM
cobalt91
cobalt91's Avatar
Have the battery tested. Autozone or O'Reilly should do it for free.
Old 08-18-14, 03:19 PM
ladytj318
ladytj318's Avatar
thank you for your reply, ive done that.
ive done all the basics to it
the general, my dad was a mechanic, (key word being (was))
so when i have a problem its been fairly easy until now
ive tested, unpluged, im just at a lost and need some insight please
Old 08-18-14, 10:37 PM
Gene01
Gene01's Avatar
One common problem is the LS400 battery cables have a connection that corrodes just inside the insulation a few inches from the positive terminal itself. The corrosion forms a high resistance that will allow enough current to pass for the accessories, but not enough for the starter motor. Have the person that checked the battery take a close look at the cables. (I am assuming that he knew how to test the battery voltage correctly).
Question - when you turn the key to "start", is it really "nothing" or do you hear a click or possibly the engine cranking?
Old 08-19-14, 02:42 AM
Yamae
Yamae's Avatar
Was an NST continuity included in your basic tests?
"No sound at all" is often caused by the NST.
Old 08-19-14, 05:41 AM
Legender
Legender's Avatar
It's tracing it out...
Key cylinder not working correctly?
Alarm locking it out?
No power to the starter due to corroded cables - does happen.
If attempted jump start makes no difference, then probably not a battery issue, but connectivity could be the problem.
Old 08-19-14, 06:28 AM
sha4000
sha4000's Avatar
thanks tracey
Like has been stated you have to define what you mean by no start.
1. You turn the key and you just hear 1 click ( Probably starter )
2. You turn key and hear several clicks ( probably battery )
3. Your turn key and you hear engine trying to turn over ( could be battery, fuel, spark and some other issues).
1 and 2 are the easiest to diagnose. 3 could have you pulling out your hair but should still be easily figured out. The key is to know what condition your dealing with at the moment.
Old 08-19-14, 01:10 PM
dicer
dicer's Avatar
Key statement was, "It was given to me". So likely the problem was already figured out, and is likely the nice and expensive starter motor replacement. Not a fun or easy job on these cars.
Old 08-20-14, 08:19 PM
technol
technol's Avatar
Put your master key in the drivers door and turn it back and forth about 4-6 times.. Then try and start the car...
smmagers
07-08-17 03:25 PM
superman08
12
11-18-13 08:14 AM
edgars
11-08-13 01:09 PM
jabernethy
05-07-12 01:48 PM
macdaddy6
05-06-12 07:08 AM
Quick Reply: 1991 lexus ls400 starting issues
