LS400 shift kit.... installed
Old 09-24-13, 01:36 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
if you run a trans cooler there should be no ill effects. The fluid will actually run slightly cooler in day to day driving because the trans isn't slipping between shifts as much (which generates more heat).
modded valve bodies when purchased alone are quite expensive.
Old 09-24-13, 01:44 PM
usoff89
usoff89's Avatar
Hit the nail on the head PD! I have plans to purchase a cooler in the near future because I also want to run a bigger stall. It's funny that a lot of people automatically think because it shifts hard, its bad for the transmission.
Thanks again guys! Oh and yes the car is extremely loud, but I love it.
Old 09-25-13, 12:32 AM
adamls2
adamls2's Avatar
I wanna be like dirty mike car sounds sick in person, and I can't wait to see this in action as well!
Old 09-25-13, 06:49 AM
simrx3
simrx3's Avatar
so ah which kit did you get?
http://www.summitracing.com/int/sear...%20shift%20kit
Old 09-25-13, 12:08 PM
usoff89
usoff89's Avatar
Transgo 340-HD2
Old 09-25-13, 06:09 PM
Sc0pe
Sc0pe's Avatar
How did it feel at 100? haha. Also, your car sounds very badass. For some reason, I think of Mad Max when I hear it...
Old 09-25-13, 06:55 PM
usoff89
usoff89's Avatar
It feels good. I just noticed your in florida. Are you going to the Orlando meet next month. So far there are about 80 clublexus members going.
Old 09-26-13, 04:53 AM
Yotarip
Yotarip's Avatar
Thanks for the vid!. I bought the same kit off ebay for the auto in my cressida but have yet to install it. It has a 1uz swap and I only shimmed the accumulators and turned up the pressure. It shifts nice and hard under hard throttle but the 1-2 shift is still laggy. The transgo kit is supposed to fix that and your vid proves it. If your ls chirps like that on the 1-2 my cressida will be crazy.
Did you adjust the pressure cable on the trans? It's the cable that runs from the throttle to the trans. Adjust the tension in the cable will raise the fluid pressure and make it shift even harder/faster. Just becareful adjust too high and cause a bind in the cable at WOT.
Old 09-26-13, 06:34 AM
usoff89
usoff89's Avatar
I haven't messed with the cable. dont think i will either, as it shifts pretty hard.
I'm sure you alreaady know, but you will never get that 1-2shift without modding the valvebody.
On a side note. This makes the car very fun to drive. Yesturday I was at a red light and the roads were a little wet. In front of me on the right hand side was a repair shop, and all the guys were standing outside. Light turned green, and i slowly rolled into the gas until WOT. The tires didn't spin, but when it caught second gear the back end came out sideways! Now you know how loud my car is, and you can imagine that this probably looked pretty bada**. I let it get sideways just enough and then let off, and just cruised by the shop. After I let off, I look over and the guys were giving me the thumbs up.
Anyway, if you install this kit be careful on wet roads if you are goofing around. Normal driving is fine though.
Old 09-26-13, 11:31 AM
Yotarip
Yotarip's Avatar
Yeah. I know drilling out the required passage in the plate and removing the selected check ball plays a part in improving the 1-2 shift. I actually grabbed a valvebody from a LS in the junkyard and installed the kit on it. I went with the extreme also. Just havent put it in the trans. The kit came with the stiffer springs and I may use my shims with the new springs.
I know about the wet traction fun. Even with my poor 1-2 shift, it can get sideways on wet streets at WOT. Your vid has me hyped to install the kit this weekend. Your LS has a 3.63 rear gear but my cress has a 4.30 with lsd. It's gonna be very fun.
Thanks for the info.
Old 09-20-21, 05:56 PM
99Slicktop
10th Gear
99Slicktop's Avatar
Default Is
Originally Posted by PureDrifter
not surprised, the SC and mk3/4 supra guys have loved this thing for years.
sadly they don't make one for the later trans :<
are there shift kits and or stalls for the 5 spd auto? I have a 99 ls400
Old 09-20-21, 07:07 PM
paulo57509
paulo57509's Avatar
I have no experience with any of these.
This just corrects funky issues.
https://transgo.com/product-details/...50e-shift-kit/
https://www.importperformancetrans.c...duct_list&c=63
INLS400
08-14-19 05:54 PM
fastegg
04-12-16 03:22 PM
mitmaks
01-20-14 10:13 PM
JTJerryls400
Performance & Maintenance
03-30-05 08:40 AM
TrboHead
13
05-04-03 09:14 AM
Quick Reply: LS400 shift kit.... installed
