Need help!!!
Old 11-25-10, 10:36 PM
cebuUSN
cebuUSN's Avatar
Default Need help!!!
HI
i have a 93' LS400
i just came back from leave and i let my sis use my car...big mistake
apparently its all jacked up
i can feel my LS wont go to 3rd gear.. and after being in second for awhile it idles like crazy as if it went to neutral??? im not sure this LS has been with me for a long time and i plan to keep it.
CAN ANYONE GIVE ME AT LEAST AN IDEA WHERE THIS PROBLEM IS COMMING FROM???
Old 11-25-10, 10:42 PM
SChema
SChema's Avatar
First things first and check engine lights?
Old 11-26-10, 07:10 AM
billydpowe
billydpowe's Avatar
thats right, check all codes, check all fluid levels, manual shift the car thru the gears, first, second, third, and drive...... under power, then come back and tell us what you found.
the answer to your question above is replace the transmission.... for a starting place.
Old 11-26-10, 11:58 AM
RA40
Super Moderator
RA40's Avatar
Then have sis pay for repairs.
Old 11-26-10, 12:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
second this.
then change the fluid to toyota t-iv (make sure she didnt have some random shop do "work" on it) and then worst case scenario you have to swap the trans, which isnt as bad as you'd think.
Old 11-26-10, 12:57 PM
sdls
sdls's Avatar
I am positive that you need to change your transmission filter.
chris07is
Performance
07-20-14 11:17 AM
abelvee
06-02-14 08:53 PM
gach2
05-13-13 11:10 PM
str8evl
04-22-13 05:30 AM
BigJohnLs
12-15-10 02:47 PM
Quick Reply: Need help!!!
