I just bought another 99 LS400
Old 08-28-10, 08:14 PM
billydpowe
billydpowe's Avatar
Default I just bought another 99 LS400
Hi, I just bought another 99, and it has the tilt/tele problem.
knowing 98 and up are different, is there a cheap fix for this?
my tele is working, but my tilt is NOT.
any help appreciated and photos of the parts are needed also.
helppppppp
here is a look at it:
[IMG][/IMG]
Old 08-28-10, 08:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
same tilt fix should work on 98-00 as for 95-97.
Old 08-29-10, 05:52 AM
billydpowe
billydpowe's Avatar
no, everything is different, pop off your covers and look.
Old 08-29-10, 06:18 AM
PureDrifter
BahHumBug
i havent had the problem in my '99 but have popped that cover off since i got my '99 and it looked similar at the time (mind you it had been ~2years since i'd fixed the one in my '95).
so is it grinding or making noise as you try the tilt or is the motor not starting at all?
Old 08-29-10, 07:54 AM
Kansas
Kansas's Avatar
The TSIB's I posted back in 2007 have some pretty decent drawings of the tilt and telescope motors in the 99 LS: https://www.clublexus.com/forums/ls4...ion-00-ls.html
Old 08-31-10, 02:18 PM
NisMax
NisMax's Avatar
I disabled mine at the shop.
Old 09-01-10, 12:26 PM
billydpowe
billydpowe's Avatar
[IMG][/IMG]can a dealer disable it? ODB ll??
Old 09-01-10, 04:13 PM
NisMax
NisMax's Avatar
Yes I used an independent Lexus shop. They used the ODB port and a laptop.
Old 09-01-10, 04:18 PM
billydpowe
billydpowe's Avatar
thanks, good news.
Old 09-01-10, 05:00 PM
PureDrifter
BahHumBug
its not as simple as a normal code reader, you need a lexus/toyota specific scan tool that has bidirectional components only really found in professional equipment.
it's a CBEST setting.
Old 09-01-10, 08:25 PM
billydpowe
billydpowe's Avatar
here is my problem, I dont want to tear into this thing, if it has been disabled. I could not overcome that.
and what makes me think is has, is because when I just touch the key to my older 99, it starts moving...
but on the new one... nothing.. yet, if I move the switch toward me it starts extending. but I cant save it to perform again.
thats my delema....
got any wisdom for me?
Old 09-02-10, 10:04 AM
JBrady
JBrady's Avatar
Had my column replaced at apx 95k miles under warranty (CPO)
It did as you describe in that inserting key did not trigger usual automatic return to presets. I was too busy at the time and I am unsure what was done other than replacement. Took extra time as they requested factory approval. This actually happened while it was in the shop for a catalyst replacement. Good timing on both from a warranty perspective since the CPO was for 100k.
Old 09-02-10, 10:05 AM
JBrady
JBrady's Avatar
BTW clean LS. How many miles and what did you pay?
Old 09-02-10, 01:13 PM
billydpowe
billydpowe's Avatar
161k $6500
sold my 97 today 9/7
BULL3T
12
06-13-17 01:12 PM
pmesfun
28
08-04-12 12:32 PM
kayuwong
07-30-12 09:21 PM
Final Word
10-04-05 10:43 AM
saforo
08-05-04 10:12 PM
Quick Reply: I just bought another 99 LS400
