How to change 1996 LS400 window brake bulbs
Old 02-10-09, 04:50 PM
jadlexus
jadlexus's Avatar
Default How to change 1996 LS400 window brake bulbs
Does anyone know how to access the rear window brake light to change the bulbs? Thks.
Old 02-10-09, 05:22 PM
LiCelsior
Retired
LiCelsior's Avatar
should be the same as http://www.lexls.com/tutorials/light...stoplight.html
Old 02-11-09, 06:41 AM
Lexozz
Lexozz's Avatar
Its a little different for 95-00. The sub cover and the tail light housing are two seperate pieces. The tail light housing can be pulled out, there are no screws holding it.
Old 02-11-09, 06:52 AM
Kansas
Kansas's Avatar
Here is a photo of the rear window brake light housing on my 2000 LS400. Be careful to not break the three little red tabs on either side.
Attached Thumbnails How to change 1996 LS400 window brake bulbs-high-brake-light-low-res.jpg
Old 02-11-09, 02:37 PM
jadlexus
jadlexus's Avatar
Thanks for the input guys. Lexozz was right on the mark and Kansas the photo was very helpful. I found that it helped to press down on the parcel shelf and then get my fingers under the plastic housing. It was then easy to pull up and out.
dashan
20
10-09-21 02:57 PM
uwgbar
10-03-09 12:21 AM
rockylexus
05-31-09 06:25 AM
mdsilverman
10-29-02 05:27 PM
djr73999
Maintenance
05-23-02 10:10 AM
Quick Reply: How to change 1996 LS400 window brake bulbs
