Blown fuse for cigarette lighters?
Old 02-16-02, 11:55 AM
Lvangundy
Guest
Posts: n/a
Default Blown fuse for cigarette lighters?
I posted this in the electronics section, but it's important to me so I'm going to post here too-
RE: 1990 LS400
I was attempting to familarize myself with taking out the stock deck to hook up some audio equipment and not paying attention I had the radio turned on at the time. I was pulling out the bottom cigarette and lighter unit and the radio flased on an off. I turned everything off and put everything back together and when I went to use the cigarette lighters (either front and back) they didnt work. I took everything out and double checked connections but I'm assuming it's a fuse since the radio flashed on and off. Anyone have any ideas?
Old 02-17-02, 12:47 PM
Lvangundy
Guest
Posts: n/a
dumb. there was a screw in the lighter socket.
Old 02-18-02, 04:00 AM
additude
additude's Avatar
Wheres that screw go?
I think you need to tear it all apart again to put that screw back where it's supposed to go.
So, having the screw in the lighter did blow a fuse, right?
Old 02-18-02, 06:42 PM
Lvangundy
Guest
Posts: n/a
The screw was inside the push out ashtray and fell out somehow, into the lighter socket. It was just sitting inside, the screw wasn't a piece from the actual socket.
Old 02-19-02, 04:32 AM
additude
additude's Avatar
I still think you outta tear it apart again just to check and make sure.
Old 02-19-02, 07:52 AM
Lvangundy
Guest
Posts: n/a
The screw came from the orignal subwoofer mount, I put the screw in the ashtray so I wouldn't lose it. But I guess it did get misplaced haha.
Old 02-24-02, 06:05 AM
RODDMOD
RODDMOD's Avatar
Default Lighter fuse
Your wire to the fuse box is open the only way to fix it is to run a new wire to the fuse box. Been there done that.
Old 02-24-02, 11:09 AM
Lvangundy
Guest
Posts: n/a
No, I thin keeveryone is looking too far into this, the problem turned it to be something simple, there was a small screw that fell inside the lighter socket. When I'd plug something into it the would pop and not work again. I changed the fuse, took out the screw and it was alll good again.
SuperCoupe400
Performance & Maintenance
09-22-20 10:56 AM
Mr Jokster
07-16-13 04:51 PM
tytgs300
08-25-08 10:44 AM
DaizenLex
08-11-04 02:35 PM
Lvangundy
02-16-02 11:48 PM
Quick Reply: Blown fuse for cigarette lighters?
