Tilt / Telescopic Problem ?
Old 02-16-04, 09:34 PM
Lexkost
Lexkost's Avatar
Default Tilt / Telescopic Problem ?
A few days ago I started my car a the steering wheel just move out and no tilt.I tried the switch and it made a click sound.The next day I started the car and it went to it's set spot, but the switch would not move it up and down only in and out. Now today everything worked fine. I looked at other threads but my problem seem very different.................Anybody have some advice?????????
Old 02-17-04, 10:14 AM
LexLS
LexLS's Avatar
Post
That's happened to me a couple times. The times it did it was either VERY cold or the battery was almost dead. When the car doesn't have the juice I think it just limits the non essential systems, just a theory. Now since you're in CA the cold obviously isn't your problem. The only thing I can say is check to see if your battery holds a charge, otherwise don't worry about it.
Old 02-17-04, 01:07 PM
Lexkost
Lexkost's Avatar
Earl!, The day that happened it was in the sun and inside of car was very hot and I thought it maybe the grease.........so I am going to try to bum some of a Lexus tech.........and then grease the gears.
Old 04-13-04, 06:25 AM
e1701b
e1701b's Avatar
Default telescopic failure
Any followup to this yet? I noticed my telecopic feature had died saturday. I hear the motor or relay click when I pres the switch, but no other sounds, no grinding, no nothing.
Old 04-13-04, 10:00 AM
flkey
flkey's Avatar
'03 to dealer for 10,000 mi. service for "brake clicks" and for tilt/tele failure to go to mem. pos. on start-up and
total failure of tele, tech ordered tele and tilt motors plus a universal joint etc, warranty work thankgoodness.
goodluck
flkey@earthlink.net
bacardi11
06-16-14 03:58 PM
DavidinCT
RX - 1st Gen (1999-2003)
03-19-10 08:03 PM
mikeho
11-05-08 11:17 AM
kglexus1
02-06-06 11:16 PM
Quick Reply: Tilt / Telescopic Problem ?
