Help!- Horn, wipers, sunroof
I'm having a few issues with my 92 ls400
The horn does not work, it seems to click when I press it and I believe it worked for a short period of time. But it isn't working now.
Also, my windshield wipers are not working, I don't hear the motor spinning, I replaced the fuse, but I'm not sure of which relay it is to be able to test it or where I can get a replacement.
And finally, my sunroof doesn't seal fully, the back end of it doesn't come up and meet the roof of the car and it sits tilted allowing a LOT of water to come in which I found out today when I went into the car wash and had to use my clothes to hold the water back.
The controls for it are pretty wonky, you have to press a weird assortment of buttons to get it to open or close. Open, then tilt, open, tilt the other direction, and then open til it opens. And a similar pattern to get it to shut as far as it does
The horn problem could be the horn it self or the clock spring wiring in the steering column. Wipers maybe the switch is not working. Moon roof, if it was me I'd try the manual closing procedure to see if that works. Then start trouble shooting it. There are adjustments that can be made to lift or lower the roof but it needs to be completely closed first.
Also, how do I adjust the rear height? I tried to re-arrange the metal shims that are between the bolts and nuts and almost rounded off the threads trying to squeeze the nut back on
This is what the owners manual says to do.
Step 1, Remove the lens from the personal lamp. (That's the courtesy light near the rear view mirror)
Step 2, Unscrew the 3 screws inside with a screw driver.
Step 3, Remove the switch base and remove the screw inside. (it is pictured as a screw with a washer and some spacers in the middle of a round drive lug with a lever looking thing near it.)
It is showing to use the L shaped screw driver for the steps below.
Step 4, To close: Close the moon roof by hand as far as it will go. Then insert the screwdriver into the hole (that the other screw was removed from) and turn the drive shaft counter clockwise until the moon roof is completely closed.
To lower: Insert the screw driver into the hole and turn the drive shaft clockwise until the rear end of the moon roof is completely lowered.
If you are out of threads for adjustment then there is something wrong with the track or rollers, did some one put a lot of weight on it? To really access any of the major parts up there means pretty much removing a lot of interior parts and removing the head liner, I think the seats can stay in but lots of other plastic moldings have to come out.
Or some timing could be out alignment with that drive and motor control, I'll have to look and see if there is an ecu for the moon roof ?
There is a switch cam that needs to be in proper alignment and that would make the motor not close or open it correctly. looked in the book......
opisdfagjo
Performance & Maintenance
10-21-18 02:24 AM
