changed starter,starts but ill not accelerate
Old 04-12-14, 02:00 PM
dsls400
dsls400's Avatar
Default changed starter,starts but ill not accelerate
Hello, just finished installing starter on ls400 1994. it starts and idles fine, but will not accelerate at all. At first re start there was a cel(did not have before repair) it was code 41 tps, so I happened to have one and replaced it. cel is gone, but car will not accelerate.. it ran perfect before starter failed. I do not notice any vacuum leaks or fuel leake and without a code I have no idea where to look...
Old 04-12-14, 02:01 PM
dsls400
dsls400's Avatar
btw, the car idles smooth as silk
Old 04-12-14, 06:17 PM
Doc Yota
Doc Yota's Avatar
Does the motor rev when you press the gas?
Old 04-12-14, 06:21 PM
sha4000
sha4000's Avatar
You check the tranny fluid to see if its low. Like Doc said, does te motor rev?
Old 04-12-14, 06:52 PM
dsls400
dsls400's Avatar
no. will not rev. just spits sputters, then dies...will start right back up, but will only idle
Old 04-12-14, 07:33 PM
python
python's Avatar
didn't do this before u worked on it?
now it is having this problem?
Old 04-12-14, 08:22 PM
Doc Yota
Doc Yota's Avatar
Does that model have a throttle body motor? Does it sputter and die after you press the gas? If so, try flooring it in park or neutral and see what it does. BTW, did you clean the intake or throttle body while you had it broken down?
Old 04-13-14, 05:07 AM
dsls400
dsls400's Avatar
No, it ran perfect before, always has. This is something that came up since the repair. Yes, I cleaned the tb and intake while it was apart. It really has me confused, because I don't know if its a fuel or spark issue. It really sucks to have that much time invested in the starter repair, then it not run & not knowing what to fix... if there were codes. id at least know where to look.
Thanks,Skip
Old 04-13-14, 08:09 AM
python
python's Avatar
ok..didn't do it before u worked on it..does it now. its obviously something u overlooked when u put it back together.
Old 04-13-14, 08:23 AM
sha4000
sha4000's Avatar
^^^^ You need to go over your breakdown and then make sure you attached ALL connectors.
Old 04-13-14, 01:07 PM
dsls400
dsls400's Avatar
I'm pretty sure it is fuel related. was kind of hard to get video correctly, but if you spray starting fluid into system it will rev with rotation of tb as far As tps goes, it is as I can get it with it not running correctly I went through that years ago. that's how I ended up with one. it was my ecu back then kept giving the tps code, even with new one.
Old 04-13-14, 04:29 PM
Doc Yota
Doc Yota's Avatar
May be spark related. My del sol has done the same thing when the plugs got old. Now that I think about it, I had an 88 Pontiac LeMans back in college that did something similar. The LeMans would idle fine but gave me hell trying to start it, and as soon as I pressed the gas it would sputter and die. I changed the plugs, d-cap, and rotor and everything was fine.
Old 04-13-14, 06:49 PM
dsls400
dsls400's Avatar
ya, I have had problems like that b4. it ran fine 2 days ago when I tore it apart
avhart
01-14-19 09:24 AM
ZabbyNab
05-02-18 03:48 AM
daddyduke
07-15-16 07:02 PM
aks92sc400
SC- 1st Gen (1992-2000)
15
12-22-13 07:30 PM
Quick Reply: changed starter,starts but ill not accelerate
