Why does the "LOW ENGINE COOLANT LEVEL WARNING LIGHT" keep going off
Old 03-18-07, 03:31 PM
jgmcs
jgmcs's Avatar
Default Why does the "LOW ENGINE COOLANT LEVEL WARNING LIGHT" keep going off
This light keeps going on and off, the car is not overheating, however when I look right infront of the driver side front tire where the revervoir drains, its wet and smells like anti freeze, I keep adding water just to be safe, but I think I might be fillin up the reservoir too much. The problem with that is that even if I leave the reservoir alone after driving 100+ miles the light will keep going off, without the extra water in the reservoir, what is happening and how do I fix it. Will an flushing the radiator help, there are no visible leaks anywhere in the cooling system.
Old 03-18-07, 03:35 PM
RA40
Super Moderator
RA40's Avatar
If the radiator cap is old, try replacing that first. May need a new sensor if all else is correct.
Old 03-18-07, 03:56 PM
XxSC400xX
XxSC400xX's Avatar
I'm not positive if it works on the LS, but on the SC's just unplug the sensor and the light will never come on again.
rkirkbride
04-03-07 08:02 PM
Carib
Performance & Maintenance
05-01-06 07:56 AM
sonyman
Maintenance
14
08-01-05 12:48 PM
antn
Maintenance
03-22-05 12:26 AM
Quick Reply: Why does the "LOW ENGINE COOLANT LEVEL WARNING LIGHT" keep going off
