Bi-Xenon
Bi-Xenon
Whats goin on?
I was wondering if anyone every went from just regular halogens to Bi-Xenon? Right now I have 6500K HIDs in my lowbeams, but I have been wanting to get some new bulbs because the 6500K arent quite bright enough. So Ive been looking into 4300K, then I realized I could maybe get Bi-Xenon. The only thing is I cant find any Bi-Xenon bulbs. If anyone knows where I can get some bi-xenon bulbs please let me know, otherwise I guess Ill just get some normal 4300K bulbs.
unfortuneately bixenon isnt in the bulbs, it would take quite a bit more work to get bixenons in your car. Your best bet would be to go 4300k, it should make a difference.
Also if you are using your OEM housings, I would recomend you have them cleaned (like the projector lens, from the inside, and reflector bow) as well as polishing the headlight lens. Unless you have new/really good cond. headlights, then you are pretty much at optimum for 6500k and OEM housings.
You could swap your projector lenses with clear ones, but to get bixenons you would have to take out your projector and retrofit some bixenon projectors.
ANOTHER thing you could do is get a modded ballast I think they can make them adjustable up to 75w and then go with a 50w bulb, from the results I have seen, there is quite a noticeable difference from regular OEM 35w 4300k. This would probably be the easiest route for you, if you can find the ballast and bulbs (kind of rare and can get sorta pricey) but still should be cheaper than a retrofit.
Also you could add another kit to your highbeams, that would be your closest thing to bixenon without a retrofit.
I explained bixenon a little more thorough in this thread: https://www.clublexus.com/forums/sho...d.php?t=251473
Good luck
Good luck
sounds good, trust me the results are worth it, I havent got around to it in my GS yet, but I plan to maybe next spring (still have some maintenance to get done).
Aso and when you get the projectors, you can mod them via: washer and shield mod, so that when you put them in you get really good results, with a really nice colorful cutoff. You will have the brightness of oem 4300k but with the flicker giving off crazy color that no 6000,8000,10000k bulb can replicate.
From what I understand, Bi-Xenon is simply a motor that drops down the cutoff shield inside the projector when the high beam switch is turned on. Sounds cool, but is not necessary unless you drive on a lot of empty roads. If you really want clarity, go for the 4300k. If you are really serious about lighting, retrofit to some S2000 or TSX projectors.
LXMN makes a good point, def cant go wrong with s2K/TSX/ and ZKW projectors, you would still get very decent results after modding a 350z FX projectors, some other projectors to keep in mind are e46 ECE/Audi ECE, e55, EVO8, and TL there are more, but those are the majority of OEM that are chosen.
ONE THING TO CONSIDER is most of the best output (clear lensed) projectors are NOT bixenon like the S2K
Former Vendor
Abear,
I agree with everything above and this is what I would do if I were you...
1) Clean up your headlamps A LOT. Pick up some Mother's Aluminum/Billet metal polish and use them on your headlights, the polish will take out any haze that you may have on the plastic. If you need to do this on the inside as well, then just bite the bullet and pull the housings, pull the apart the plastic and really really clean up the inside layer of the plastic housing and the half spherical lens.
2) Run 4300k HID bulbs. There is actually a 12-15% loss of visible light output from 4300k to 6000k. The reason why I say "visible light output" is because you're still putting out the same amount of light but the darker blue tinted light just doesn't show up as easily on the road as a pure white light.
3) Of course - make sure your lights are aimed properly... I know - sounds dumb and simple but just humor yourself and check. It can make a huge difference.
4) The 50w ballast idea isn't a bad idea if you can get your hands on them. I've been thinking of doing that in my car as well just for fun and since it wouldn't cost me much, I think I will give them a try in the next month or two. I'll let you know about my findings.
5) If you still can't see out there after doing the above, perhaps a 9005 HID kit in your highs??
Bring this thread back, as I have found the projectors I want to use.
I never did do anything besides adjust my headlight aim, which helped.
Anyway, I moved back to Houston and no more unlit backroads, but I still want to do a retrofit. Just something I would love to learn to do.
Ok, so I work for BMW..I know, I drive a Lexus and work for BMW.
Anyway, we got some broken E92 projectors in on a body shop car(a car someone wrecked but the body shops fixin it up). The projectors are fine, what I meant was the headlight is broken. One of the tabs got ripped off, so it doesnt sit still in the housing so they were just gonna throw it out..I said hell no.
No I have a brand new E92(328 coupe) headlight sittin on the floor next to me. Its got the bi-xenon and everything. The only thing is, is that I will have to get another one, but no big rush, I just need something to play around with right now. I plan on opening it up this weekend to get the projector and everything else out so I can have a look see.
Someone told me that doing a Bi-xenon retrofit is hard, something like the bi-xenon wont stay on or something. Does anyone know about this? Either way these are the projectors Im gonna use, they look great when riding, nice wide range and ALOT of light output, at least compared to mine.
little2576
02-17-16 10:51 AM
