Lexus Customer Service (archive) The Lexus Customer Service forum on Club Lexus has been inactivated at this time, but past posts will be left as a visible archive forum for a period of time.
[Other] Car slowly shut off
Old 04-26-15, 10:21 AM
LexyAzHell
LexyAzHell's Avatar
Default Car slowly shut off
Hey guys, I have a completely stock 1993 sc300 that I just recently bought for $800. And now is starting to run like an $800 car. Anyways, the positive battery cable had been loose for a while, so sometimes I would have to reconnect it when turning the car on. Yesterday, I was going over a pretty bumpy road and when I got home noticed that the cable was disconnected. So I was driving without it on. Now when I start the car, it idles a little lower than usual and then eventually dies in me. I hooked it up to my other cars battery to try and charge it. And it seemed to work. I only charged it for 5 min though. So my question is, does the battery just need recharging or is there something else going on? Thanks. -Austin
LexyAzHell is offline
Old 04-27-15, 01:46 PM
LexCareSP
LexCareSP's Avatar
Hello LexyAzHell, we apologize as we are not in a position to address this concern. We recommend you consult with your local Lexus Dealer as the technicians will be in the best position to address your inquiry. We apologize for any inconvenience this may cause you
LexCareSP is offline
Old 05-04-15, 11:21 AM
gerrb
Super Moderator
gerrb's Avatar
Battery voltage supply to the ECU is critical on these cars. It has to be at around >13.8v if your alternator is charging right. Otherwise that idle will be fluctuating up and down as voltage going to that ECU is going down below 12v.
Fully charge the battery and tighten well your battery terminals making sure there are no corrosion and your alternator is charging well the battery.
gerrb is offline
Lexi66
ES - 5th Gen (2007-2012)
02-25-18 09:42 AM
Lookyoung
RX - 3rd Gen (2010-2015)
01-07-13 06:18 AM
Xwakeboard
05-21-10 01:53 PM
19ES250
Maintenance
11-10-06 06:31 PM
Brian S
Maintenance
03-14-02 05:40 AM
Quick Reply: [Other] Car slowly shut off
