Chirping sound in the engine
Old 04-24-13, 08:32 PM
aznKewlguy
aznKewlguy's Avatar
I have that noise too.. Sometimes it squeals while is running. I've changed the serpentine belt and it still squeals, I've come down to it being the belt tensioner. Gonna get it changed s
Old 04-24-13, 10:45 PM
Ramon
Ramon's Avatar
Originally Posted by Toxicxk23
Hey sorry I haven't been around. Busy at work. Quick update though, "chirping" sound hasn't gotten worse or better. It seems to be coming from the front driver side near the belt. I have to look into it more when I find time. However, a new sound has arised. It's only happened a few times and I can't make it make the sound. When I start the car for about a quick second the engine sounds like a food dispenser with a metal fork in it. Not a good sound at all and it's kinda sketching me out.
I'll get video of the chirping hopefully soon and the 2nd noise...well I can't replicate it =(
There's a TSB for the cam rattle. Unfortunately it's not a recall so if you're no longer under warranty, you're kind of SOL.
Old 04-25-13, 04:20 PM
Toxicxk23
Toxicxk23's Avatar
Originally Posted by Gville350
That start-up sound is the notorious "cam rattle".
Is there a fix for the cam rattle and what is the effects of it? Will it continue to get worse and damage my car?
Old 04-25-13, 05:29 PM
Ramon
Ramon's Avatar
Yes, there's a fix, I had it done to my car. Luckily when it started, I was still under warranty and it was covered. I'm not certain what the details of the fix are or if it would damage your engine in the long term if left alone. Obviously you can still get it fixed if you're out of warranty, you'll just have to come out of pocket for it.
Old 04-25-13, 06:31 PM
Toxicxk23
Toxicxk23's Avatar
Any idea on approx. cost?
Old 04-25-13, 11:19 PM
Ramon
Ramon's Avatar
Sorry, no clue. I've long since shredded that invoice.
Old 06-14-13, 06:51 AM
micel
micel's Avatar
Default noise
Rub a bar of soap on belt,if noise goes away ,bad belt.I bought a new belt that was bad also.
Old 05-19-14, 10:51 AM
GaryRama
GaryRama's Avatar
I'm getting relatively steady chirping out of my engine compartment too. On start up, somewhat slow and as the engine warms up a little steadier. I too am hoping it's the serpentine belt. 2003 LX 470 with 88K miles.
Old 05-19-14, 12:58 PM
Gville350
Gville350's Avatar
Replacing the belt fixed my chirp, and that was after I had purchased a new accessory pulley for NO reason.
Old 05-19-14, 06:07 PM
Joelseff
Joelseff's Avatar
Are you sure it's not a "whirrr" sound? Mine does this right after I shut down the car. It comes from the front somewhere. Sounds like a servo or something. I thought it was some electronic doodad in the car Now I'm kinda tripping
Old 11-09-14, 11:11 PM
commando45
commando45's Avatar
I have the same symptom. as the engine is shutting off, and the pulleys are coming to a stop, there is a bird chirp that you can hear. i have already replaced the serpentine belt, tensioner pulley and idler pulley. some people say it could be the alternator pulley where inside of the pulley cover, there is rust which you can try and get out to see if that is the problem. if not, i would say is the tensioner assembly. i'm in the process of wanting to swap out the tensioner assembly completely with a new one. i will also try to load up a video of it to show the community what we are talking about, since no one yet has been able to upload one.
Old 11-14-14, 03:33 PM
commando45
commando45's Avatar
does it sound like this?
this is a video of my car making the chirp noise as it shuts off
Old 11-14-14, 05:20 PM
Gville350
Gville350's Avatar
^Not so much as chirp in that video as a squeal or squeak; but nonetheless, that's something that I'd call normal.
STREETGS
07-28-16 05:18 PM
O. L. T.
Performance & Maintenance
38
11-20-11 04:24 PM
Klovely341
05-31-11 05:12 AM
nyoko
10-22-08 08:48 AM
$C300
01-22-07 09:11 PM
Quick Reply: Chirping sound in the engine
