Frame damage cause misalignment?
Old 02-19-12, 10:13 PM
fastrider
fastrider's Avatar
Default Frame damage cause misalignment?
Ok, I posted here a while ago asking questions on tires and wheels because the collision center screwed up pretty badly.
After hitting a curb going approx. 40 mph, both of my left wheels were damaged. At the end of the day, the insurance company purchased 2 new wheels to the left and I ended up getting all 4 new tires. Due to the issues I've had after getting the car back, the alignment was performed twice, once by the collision center and second by NTB. (this was because the collision center ended up putting my wider rear wheel to the front and vice versa which I thought was the cause of my steering wheel not lining up correctly)
Right now, the car seems fine, some noise I heard initally seems to go away and nothing else is wrong. However, the steer wheel has to be turned at an angle to the right, approx. 20 degrees?, for the car to go straight. The alignment report says the car is aligned. The tires are new and wheels are good. When the collision center fixed the car, it had reported that there were some frame damage to the left side of the car near top of the doors where it touches the body. Does this cause some kind of misalignment?
Is there any way so that I can just reset the steering wheel slightly to the left so that the natural disposition of the steering wheel when straight will make the car go straight?
Thanks
Old 02-19-12, 11:53 PM
chi123
chi123's Avatar
Frame damage does cause misalignment. However, I got frame damage from an accident after getting hit by a car going 30-40 MPH on the side but my car drives like before. You should have that frame damage taken care of first though.
Old 02-20-12, 12:59 AM
SCWB
SCWB's Avatar
Get your car to the reputable bodyshop, have them put your car on the frame alignment/jig machine to see if there are any tweaks on your chassis. Chassis is the fundamental for wheel alignment. Might have to check for bent or distorted suspension component as well.
Old 02-20-12, 02:48 AM
jgbackes
jgbackes's Avatar
It's pretty common mistake for an alignment shop to forget to recenter the wheel during the process. If you take it back, they should be able to recenter the wheel for you
jeff
Old 02-20-12, 12:08 PM
Gville350
Gville350's Avatar
jeff
That was gonna be my question. I'm by no means an alignment guru, but I'd think that before the alignment is performed a GOOD tech would check the steering wheel.
Old 02-20-12, 01:59 PM
Sango
Sango's Avatar
Check if the sub frame bolts torqued to proper specs.
When I had my Solara, the car had to be aligned a few times and eventually complained to corporate (cuz they wanted to me to pay for another alignment charge which I did). When the car was aligned, it would stay good for about a few minutes or so then it goes completely out. Would do this on crowns or going around a corner hard enough.
Went there a few times and showed me the result showing it was good after it was done but it wasn't until after the fact it went out - put it on the rack, it was bad again.... They were saying it was my after struts, which I know isn't true because it was good before the alignment had taken place.
On the 5th time, they finally found the problem. This time, they used a torque gun to check all the bolts, then they found a loose sub bolt to me the culprit. Once they got it addressed, they were able to align it and it stopped going out. When it was loose, it would go with the sub frame would shift under the weight of the car which would bring everything out of alignment. They were not sure why it was loose, but considering the car had over 210, 000 miles + on it, something must of happened.
To be honest, I think they should of suspected that from the first time I brought it back instead of the 5th time after complaining every-time I gotten the car back supposedly after it was re-aligned.
Old 02-20-12, 05:44 PM
fastrider
fastrider's Avatar
Thanks for the info. I just took it back to NTB tonight and they aligned it again. This time, I was there next to the technician and explained that the car keeps drifting left when the steering wheel is pointed straight. He calibrated something on the computer, then did some bolt stuff below in front of the car, near the bearings I think, and the car does seem better. Not sure if it'll last but it is than before.
Old 02-20-12, 05:45 PM
fastrider
fastrider's Avatar
Yea, I lost faith relying on the mechanics who prob don't care too much how precise their work is.
JDR76
03-19-16 06:33 AM
Stew4HD
Suspension
10-12-13 05:39 AM
djyoshi626
CL of Southern California
11-22-09 04:37 PM
iammikey
08-18-04 09:55 PM
Ex996
Suspension and Brakes
12-05-02 07:11 PM
Quick Reply: Frame damage cause misalignment?
