IS 300 engine question?
Hello everyone. I recently purchased a 2001 IS 300 for my son. And I was wondering if the engine in the car is the same as the engine that was supplied in the Toyota Supra except perhaps for the updated valve timing and fuel injection system? Thanks...
Originally Posted by wilddave
The supra came with the 2JZ-GTE engine (T is for Turbo), The IS300 has a 2JZ-GE. The block is very similar, but our engine has a slightly different head, cams, and internals. Our ingine also has the VVT-i on the cam.
Lexus Connoisseur
JZA80 - N/A Supra 2JZ-GE was 225 hp.
PICTORIAL DIFFERENCES
Supra N/A 1993-1997 2JZ-GE
notice the distributor
Supra/NA in 1998 had the exact same 2JZ-GE VVT-I that we have on IS300's
Supra TT 93-98 2JZ-GTE
IS300 2JZ-GE VVT-I
IS300 2JZ-GE VVT-I
Originally Posted by bchau_gt
Marc, good post, but are you sure about the above? I've seen the rods from an IS300 and they're even different than ones from a GS300 (not as thick). I suspect that the 1998 2JZ-GE with VVTi also has stronger internals than the current IS300 version.
Originally Posted by eHIGH
I've always heard same as IS
not true...the IS300's motor is signifigantly different
the Sc300's 2JZ-GE is also the same as the Supra 93-97 N./A
*distributor
* non drive by wire
* non vvti-i
* rods/pistons slightly bigger/stronger then IS300 counterpart
