Key fob crap out!
Old 10-28-12, 03:15 PM
chris6878
chris6878's Avatar
Default Key fob crap out!
So I drive my 08 f to the store. I get out the car and my key doesn't lock the car. I think nothing of it so I lock the car manually....big mistake. I go to the store and come back and the key still doesn't work. Car locked cant get in.
I then try to manually unlock the car with the key stick. That **** didn't even fit in the key hole. So I walk home to get my other key. I get a ride back to the car and the other key doesn't work either. I can't do it manually with the key stick either.
I end up calling aaa to unlock the door. Aaa arrives and unlocks the door. The alarm goes off and my keys still aren't working. Locksmith tells me to hold the key next to the start button. Magically it works and I can drive home. I wake up the next day and both keys are working minus the key stick.
It also happen to my wife in my 2011 es. Luckily she didn't lock the door. She also had to put the key next to the start button to get it to work.
I went to the dealer today to let them figure it out why my auto and manual keys didn't work. Meanwhile I have a fresh white on white 2013 gs as a loaner.
Anyone else ever ran into this situation. Thanks
Old 10-28-12, 04:12 PM
FD3SISF
FD3SISF's Avatar
You battery may need replacement.
Old 10-28-12, 05:29 PM
chris6878
chris6878's Avatar
Yea I was thinking that but I was amazed that both keys are in need of replacement at the same time
Old 10-29-12, 07:46 AM
DCoolBeans
DCoolBeans's Avatar
Sounds like a dead/dying battery because you were able to turn on the car with the remote as close as possible to the ignition
Old 10-29-12, 07:14 PM
Gryder
Gryder's Avatar
Similar situation happened to me a few weeks ago, in the
end dealer ended up resetting the system.
Old 10-29-12, 07:29 PM
Lexura1414
Lexura1414's Avatar
Did you get a low Key Fob battery warning? I always get this warning..
Old 10-30-12, 04:46 AM
chris6878
chris6878's Avatar
Not at all. Just crapped out on me
Old 10-30-12, 01:16 PM
Kevin.IS
Kevin.IS's Avatar
Had that happen to both my keys before, but after replacing the battery to the key fob everything work correctly again.
FoxfireNC
09-22-13 08:13 AM
marcoeva
02-03-13 06:55 AM
felixdang
10-07-11 04:20 AM
trademark
SC- 1st Gen (1992-2000)
23
07-10-11 02:02 PM
Butta
07-24-05 09:33 PM
Quick Reply: Key fob crap out!
