Partially frozen nav system
Old 10-26-15, 03:19 PM
bryan11
bryan11's Avatar
Default Partially frozen nav system
My 2008 is350 with 125,000 miles supposedly had the NAV system fixed by the dealer by the previous owner. It's worked fine for about 6000 miles, but when I tried to tell the system I just got an oil change it stopped working normally partially frozen. I pressed the side INFO button, maintenance, and then tried to select an oil change and it went to the screen to select a language. It's stuck there. I can press INFO again, press the screen for maintenance, and it goes to the language screen again. Pressing anywhere on the 'select language' screen then doesn't do anything.
The side buttons around the NAV system all work and change the screen display.
What are the steps to try to recover from this? Disconnect the battery for a while? I've ready about taking the system out to get it fixed a while ago, but hope to try all other steps first, of course.
Thanks,
Bryan
Old 10-27-15, 04:50 PM
whitebeast
whitebeast's Avatar
You have touchscreen problem like a lot of other member has. You could use DIY frozen navigation fix to fix your.
Old 10-27-15, 06:10 PM
bryan11
bryan11's Avatar
Thanks. Since it accepted input for a few screens, it wasn't sure if that DIY applied in my case.
Old 10-28-15, 08:46 PM
whitebeast
whitebeast's Avatar
Take video of it so we could help you out better. What version of your DVD MAP?
Old 10-28-15, 09:39 PM
Bichon
Super Moderator
Bichon's Avatar
Meanwhile, the main oil change reminder is not reset via the nav system. Here is a thread from our FAQ about how to reset it: https://www.clublexus.com/forums/is-...ml#post1723025
ac281
08-24-16 05:29 PM
Lexus61030
06-14-16 07:45 PM
DMVLS600HL
03-17-16 10:53 AM
MD350
01-27-08 06:08 PM
looknow12
09-07-05 04:39 AM
Quick Reply: Partially frozen nav system
