Alignment Problem (Report Attached)
Old 10-31-12, 09:54 PM
sallydrive
sallydrive's Avatar
Originally Posted by Sango
I would ask if they they know hot to adjust the sub-frame.
Dedicated alignments shops would be capable of doing this.
I went to a dedicated alignment shop, and they said they couldn't adjust the subframe. They said if they do it would throw of the other side., however they could adjust my steering wheel to compensate for the pulling. Any other help is highly appreciated.
Old 10-31-12, 10:25 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,077 Likes on 2,471 Posts
They're idiots. It will affect the other side, but it's just as screwed up. You're looking for balance between right and left, and you currently do not have balance at all. If they reposition the subframe correctly, your camber and caster will be within the normal range and you should be better off.
Simple arithmetic shows this - if you add the front camber (left + right) you get -0.7 + - 1.5 = -2.2. If you divide -2.2 by 2 which is what happens if you move the subframe toward the left side, you'll get exactly -1.1 on both sides which is precisely what the alignment sheet says it should be.
A number of IS-F owners have done this. It works very well and makes the car drive straight without any steering corrections at all.
The FIGS bushings will fix the inside edge wear problem almost all the 2IS have in the front. Nothing else will, not even repeated changes to alignment.
Old 10-31-12, 11:22 PM
Sango
Sango's Avatar
Then it sounds like the shop you went to are incapable of doing this.
What lobuxracer saids is pretty much correct. Basically need to find the right shop which can position the geometry appropriately to get within the correct ranges then the car can be properly aligned.
I do recommend FIGS bushings. I will do this to my vehicle when I switch to my winter tires.
Old 10-31-12, 11:55 PM
FIGS
The Maker
FIGS's Avatar
We are also getting install data on the eccentric version of the rear arm bushing to give "clock" positions for some other forms of corrections to caster angles. Something that you might not consider is that a multi-link rear suspension has quite a bit of steering influence. If toe is off in the rear it can impact the front steering. So it is important to align the rear first, then the front. Get the rear toe values balanced before you mess with the front and I am willing to bet it will help. On lowered cars this made even worse with the inclination angle of the toe link causing bump steer which is why we have length adjusting links to mitigate that. vs teh stock eccentric mount on a fixed length link. Above all the tools are only as good as the mechanic using them. If you cannot find a shop that understands simple geometry then all the adjustments will make no difference.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 11-05-12, 01:18 AM
sallydrive
sallydrive's Avatar
I understand what your saying completely, and it makes sense to me as well, but now I've taken it to 2 places and they don't know what I'm talking about. Does anyone know any GOOD falignment places in Houston TX?!
ayman01
NX - 1st Gen (2015-2021)
10-03-17 05:37 AM
almost_g
11-16-07 07:26 AM
hashs99
01-12-06 06:28 AM
Lvangundy
Maintenance
04-08-03 10:33 AM
Quick Reply: Alignment Problem (Report Attached)
