? On front seats when removing... Please help
So I'm removing my front seats to change out the carpet but wasn't sure how to go about it.
1 do I remove the battery cable before disconnecting the seats?
2 will the Air bag indicator light go on if I remove the seats
3 is it ok to connect the battery cable again after removing the seats?
4 will The Air bag reset after reconnecting battery
Help please. Thank you.
I changed out my carpet a few months ago and had the exact same questions as you.
1.) yes, 100% disconnect the battery before removing the seats, as the airbag light could go off
2.) the airbag light will not go off as long as you disconnect the battery BEFORE removing the seats
3.) DO NOT connect the battery as long as the seats are removed
4.) airbag lights do not reset, you have to go to the dealer i believe, (i am not sure about this one)
An extra note, move the seat all the way forward and tilt them before you disconnect the battery. It'll make it easier for you to get the seat out of the doorways, especially since you wont have power after you disconnect the battery
Mikey I'm in central mass worecester area. It's an easy 15 min job to do. I've also learned you don't need to take out the seat to change the secondary sensor. Took me a few time of doing it to realize it haha.. No issues at all if you don't disconnect the battery. Just make sure you connect everything back when your done.
Is removing the seats a hard thing to do? I'm trying to replace my driver's seat, probably find a used one somehow, somewhere... dealer wants to charge $2500+ for a new seat and labour... I'm thinking I can secondhand one a lot cheaper and do it myself if it's as easy as y'all make it seem..
Mcon
08-12-17 05:16 PM
