Reattaching the mud flaps?
One of mine was missing and the other was dangling. I stopped by the Lexus dealer and picked up the one bracket for $30ish and the clips for another $10. I also drilled another hole through the bracket and used a sheet metal screw to hold them on better. No issues since.
can anyone give me the part# for the "mud guard" and the screw? mine is doing the same thing now and cant search from sewell anymore.. thanks
found them
for reference:
it's called "rear floor housing shield"
57498A - rear driver
57497A - rear passenger
75867A - push pin/clip
found them
for reference:
found them
for reference:
found them
for reference:
Peace
Bruce in Philly
I initially replaced the clips, but they just broke again over time so I just zip tied them as well. The zip ties will last a lot longer than the chintzy clips and you can't see it anyway so it's a non issue.
I had the same problem, went by my local lexus parts dept. The gave me the replacement plugs for free. Super easy to fix. Good luck !
I bought these at AutoZone. Still good and never popped off again. They are a slightly larger diameter, and grab well vs OEM.
https://www.clublexus.com/forums/is-...eflectors.html
