Reattaching the mud flaps?
Old 04-08-12, 01:27 PM
kl323
kl323's Avatar
Default Reattaching the mud flaps?
Hey all,
One of the mud flaps... I think that's what it is... fell off and is only hanging on on one end. I've been using tape for a few months now. I would like a more permanent fix.
Any idea where I can get the clips to resecure them?
Thanks!
Old 04-08-12, 01:46 PM
RocketGuy3
RocketGuy3's Avatar
I don't believe those are mud flaps (they're in front of the tire afterall). I remember being told that they had something to do with controlling turbulence around the rear wheels. One of mine fell off once while it was under warranty, and I had the dealer fix it. Then the other one started hanging off out of warranty, and the dealer wanted like $132 to fix it. I just said eff that. Didn't really look into how to fix it or how worthwhile it would be to do so.
It seems like this is a common problem, though. I'm a bit surprised there isn't a recall/TSIB on it. I wonder how important those things really are.
Old 04-08-12, 02:11 PM
teefar
teefar's Avatar
I'm on the same boat as you. One is just dangling, I'm think I'm just gonna just take it off.
Old 04-08-12, 02:15 PM
KillaIS250
KillaIS250's Avatar
Mine's hanging like that currently too for the 3rd time now. First time the dealer took care of it, second time i put a clip in it (i believe it was the exact same as the ones used to hold the engine covers down). This time my car is going in for service anyways so i'm just gonna have them do it like the first time
And $132 to fix that is ridiculous. It's not even essential.
Old 04-08-12, 02:39 PM
felixsc300
felixsc300's Avatar
Mine was hanging off two months ago and my dealership ordered a new one for me. Just found out several days ago that its hanging again, smh. Toyota needs to fix this design. I did recently have a GFX kit installed and that was when this issue started occurring - would be interested in seeing if this occurs only/mainly to peeps who run the GFX?
Old 04-08-12, 02:57 PM
KillaIS250
KillaIS250's Avatar
^ Are you talking about the GFX sides? Cuz i don't have them and mine have come loose 3 times now lol
Old 04-08-12, 05:01 PM
LexusLifer
LexusLifer's Avatar
Had this happen to me on both 2IS's that I've had. It requires a simple DIY push-in clip that Sewell sells for dirt cheap. Here's the link:
http://is.sewellparts.com/accessorie...2008/1955.html
Hope this helps!
Old 04-08-12, 05:47 PM
santacruz
santacruz's Avatar
Mine started dangling so I just took it off and threw it in the trunk...it's been there for about 3 months now. haha
Old 04-08-12, 05:59 PM
oblivionis
oblivionis's Avatar
I had the dealer fix mine once, then I reattached it using the clips sold by Sewell and then when it was dangling again I gave up and took it off.
Old 04-08-12, 07:30 PM
kl323
kl323's Avatar
Thanks for the feedback.
Is it really for aerodynamics? I'll just tape it up till my next service and see what they will do for me.
Haha
Old 04-08-12, 07:50 PM
sktn77a
sktn77a's Avatar
Yes, aerodynamics. But $5.00+ for a silly little plastic clip that should cost more like 10cents ?
Old 04-08-12, 07:58 PM
Hoovey689
Hoovey689's Avatar
Haha
more like to help against flinging rock chips.
save yourself time and trouble and just go get the two little clips from the dealer and be done with it
Old 04-08-12, 08:28 PM
baypistol
baypistol's Avatar
I just used double sided tape on it yesterday and it worked.
Old 04-08-12, 08:40 PM
evogt500
evogt500's Avatar
Yes, its for aerodynamic purposes. I believe its called a fairing/deflector. Air hitting the tire straight on creates alot of turbulence and is not good for high speed or fuel economy. The fairing redurects the air to go around the tire. for smoother airflow. It is used for racing and also for those fuel misers. How well it works on the IS, is debatable.
Here is a interesting article on under-car airflow.
http://www.autospeed.com/cms/A_2456/article.html
and:
File Type: pdf
Old 04-09-12, 03:58 AM
Bichon
Super Moderator
Bichon's Avatar
I've had mine break several times too. I think the culprit is driving through a deep puddle or other standing water at high speed. The clip is strong enough to stand up against air pressure, but not water pressure.
No, the clips are significantly larger than the ones used to hold the engine covers on.
Quick Reply: Reattaching the mud flaps?
