Fuse Box Caught Fire!! Photo
Old 03-07-14, 07:40 PM
kowala
kowala's Avatar
Default Fuse Box Caught Fire!! Photo
So the past few days I've been smelling something strange coming from the air vents. Apparently either the fuse box or the fuse holder from the aftermarket sound system was slowly heating up where it eventually caught fire today. I was on the highway when I noticed smoke coming from the hood, I immediately pulled over at the nearest exit, I opened the hood and the fuse box was in flames. Luckily I was able to put the fire out before it spread any further.
Here's the damage done.
The car's electrical system still works fine and so does the audio. None of the actual wiring other than the power cable from the car's aftermarket audio system was damaged, and of course the fuse box. I'm going to replace the whole fuse box, battery, and redo the car's audio wiring.
My main question is, is the wiring to the fuse box plug and play? or would I have to solder each wire? If anyone is familiar and can help me out i'd appreciate it, thanks!
Old 03-07-14, 07:42 PM
ThomasGS4
ThomasGS4's Avatar
Yikes! Glad you caught it in the nick of time.
Old 03-07-14, 07:50 PM
offbad
offbad's Avatar
looks like your gauges were too small :\
Old 03-07-14, 07:51 PM
RainyGS
RainyGS's Avatar
Wow, that's crazy, glad you are alright. Everything looks replaceable. Have you gotten a quote on the cost to fix everything?
Old 03-07-14, 08:01 PM
Lexusjg1
Lexusjg1's Avatar
Glad you caught that in time, and made it ok.
Old 03-07-14, 08:03 PM
kowala
kowala's Avatar
tell me about it!
Yeah the smaller gauged wire that you see on top of the fuse box is actually a relay harness for the HID fog lights, the cable along side of battery and fuse box is actually the power cable for the audio lol
Thank you! I guess that's all that really matters in the end right. I called a few shops and they said they'd need to take a look to give me a quote but I estimate roughly 600 or so. It really all comes down to whether the fuse box is plug and play or not because soldering would be a pain.
Old 03-07-14, 08:07 PM
kowala
kowala's Avatar
thanks, appreciate it!
Old 03-07-14, 08:16 PM
MikeFoxx
MikeFoxx's Avatar
That wiring job though... Where is the fuse block for the amp power? Or is that melted right before the cars fuse box? Gauge is def small if thats it even for a lil 200 watt amp. Crazy bro glad ur safe though that coulda been crazy if u were stuck with no exit or shoulder to pull over.
Its possible you didnt have the right amount of amps for the fuse in that block. I had something similar even installed at a shop. My block melted a lil and i kept blowing fuses on the amp itself. Turned out that the fuse in my block by the battery wasnt big enough.
Old 03-07-14, 08:32 PM
kowala
kowala's Avatar
Thanks bro, you guys are definitely are making it better as this couldn't have come at a worse time. The fuse block for the amp WAS right below the actual fuse box lol. The cable on top of the fuse box isn't the actual power wire though, that's the fog relay. The previous owner had the audio installed and it's never given me a problem the past 5 years so it's a bit strange that this caught on fire now.
Old 03-08-14, 04:13 PM
kowala
kowala's Avatar
has anyone replaced the fuse box before or does anyone know if just replacing the box involves replacing the whole wiring harness as well?
Old 03-09-14, 06:19 AM
aliga
Former Sponsor
aliga's Avatar
I have the fusebox with fuses if u need.
NXOwner
NX - 1st Gen (2015-2021)
30
02-03-24 04:37 PM
Returd
Performance & Maintenance
03-16-17 07:23 AM
cec327
RX - 4th Gen (2016-2022)
05-10-16 12:44 PM
Spyder78
04-11-16 05:13 AM
skeet92
SC- 1st Gen (1992-2000)
06-29-14 07:42 AM
Quick Reply: Fuse Box Caught Fire!! Photo
