Pedal Position Sensor - question
Old 06-17-05, 02:21 PM
ted920
ted920's Avatar
Default Pedal Position Sensor - question
I had my car diagnosed at the dealer today (McDermott) and they determined that the cause of my VSC On/OFf and Check Engine Light problem is the Pedal Position Sensor. They said that the codes and diagnosis indicated that there is an "open circuit" in the Pedal Position Sensor.
FYI, this is a '99 GS 300 we're talking about with 45,000 miles.
They quoted me $371 to get the sensor and put it in.
Carson said the part is $69 shipped.
How easy is this for a regular shop to install on my car without any problems occuring?
How much would you expect the shop to charge?
Can anyone show me where this piece is located (supposed to be near the throttle body).
For some time now, I have had a lack of power issue, where the car runs really sluggishly to get from 10 -50mph and has major major trouble getting over 85 (it also takes forever to even get to 80-85).
FYI, so far I have changed the MAF and TPS sensors and problem still exists. Do you all think that the Pedal Position Sensor will fix my problem?
Anyone have any experience with this?
Much Thanks in advance,
Ted
Old 06-18-05, 07:10 PM
ted920
ted920's Avatar
Can anyone offer any assistance her please?
I need to decide what to do on this soon.
Thanks.
ted
Old 06-18-05, 07:13 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Ted,
I'm not sure if I've ever heard of a pedal position sensor. This is different from the throttle position sensor (TPS) or just another name for it?
Old 06-18-05, 07:36 PM
ted920
ted920's Avatar
I don;t think that this is a Throttle Position Sensor b/c I told them that I just changed the TPS very recently.
Does anyone know anything about a Pedal Position Sensor?
Ted
Old 06-19-05, 03:54 PM
chuckb
chuckb's Avatar
Ted, did you see this? https://www.clublexus.com/forums/sho...6&goto=newpost
Originally Posted by JellyBean
The dealer may have fixed my car. Shortly after my updates above, Tim the assistant service manager called and asked me to return the car as soon as I could. (He didn't know that the symptoms had resurfaced.) He explained that one of his techs wanted to replace the "accelerator pedal assembly". The tech had apparently repaired two other cars with similar symptoms. Anyway, the car was acting up when I took it in, and it's driving fine now with the new part. The invoice says that they replaced the "APP Sensor", and the part listed is a "PEDAL ASSY, ACCELERATOR". The part number appears to be 78010-30030. Lastly, they were never able to pull out any error codes.
Wish me luck. I'm hoping that this is it.
JB
Old 06-19-05, 05:07 PM
ted920
ted920's Avatar
ChuckB:
Damn you are the man!
Yes that seems to be same problem I am having.
From what Jellybean said, it seems as though there just might be a thing called the pedal position sensor. AM I reading his post correctly?
Thanks much.
Ted
Old 06-19-05, 06:24 PM
JellyBean
JellyBean's Avatar
The part number listed in my post is correct. I looked it up in a parts website. Maybe "APP Sensor" stands for "Accelerator Pedal Position Sensor". Good luck.
JB
yungtrinib
08-28-18 09:02 AM
Lexingram
07-18-14 06:01 PM
tn96dc
06-02-14 11:51 PM
ted920
Performance
11-02-04 08:33 AM
Quick Reply: Pedal Position Sensor - question
