power steering pump making noise while turning the steering wheel
Old 08-24-14, 11:14 PM
geohector
geohector's Avatar
Default power steering pump making noise while turning the steering wheel
recently had this problem, if you dont notice a leak or not losing fluid, then your pump is good.the fluid in not transfering down to your rack n pinion system.I knew how to fix but did not have time.so I took it to a mechanic who I trusted an works on all of my three toyotas.he removed the pump and cleaned the filter inside the pump (quote; the internals of a power stering pump hardly ever go bad) so its fine now.
jdub20tx
Performance & Maintenance
04-01-13 06:59 AM
redgs300
09-23-12 06:43 AM
worldforgo
02-04-12 09:47 PM
durtysc300
12-03-11 12:06 AM
ozzie
04-29-06 09:41 PM
Quick Reply: power steering pump making noise while turning the steering wheel
