F-Sport Fog
F-Sport Fog
I've looked at previous post and did lots of researches on adding fog lights on F-Sport model.
I wanted to have OE stalk for fog light switch, but didn't come up with clear answer where to tap the wire to have cluster indicator to work.
From PK_Celsior post,
https://www.clublexus.com/forums/gs-...em-switch.html
Fog Light Switch Connections
Ground
N28 Connector - Pin 10 -> N28 Connector - Pin 19
On/Off Function
N28 Connect - Pin 11 -> N12 Connector - Pin 27
It's not clear if he meant to use both 10 & 19 pin for ground for LT/RT fog lights or to connect between pin 10 to pin 19.
I don't want to spend $120+ for OE stalk if the indicator doesn't work.
Anyone successfully installed OE stalk and have indicator work, please guide me thru the wiring for the switch.
If all fails, I am thinking about hooking up to the Headlight power (no switch - just turns on everytime headlights turn on).
Does any one have good idea where to tap the headlight power??
Thanks.
Ground
On/Off Function
Thanks.
I'm also thinking about doing this as well. Please post any helpful wiring details. Thanks!!
I would love some detailed pics too lol. I had my fogs installed with the indicator years ago but something is loose and the lights don't always turn on, even if the indicator is lit. I just don't know where to find the loose pin...
Thank you!!
I've sent you a PM.
I've originally looked at your DIY, but couldn't figure out the N28 (switch connector) & N12 (module connector).
songoku
04-05-21 09:50 AM
avalon42
01-21-09 08:41 PM
