Fog Lights
Old 04-11-16, 11:54 AM
frotiss
frotiss's Avatar
Default Fog Lights
Hey Guys, I change my Fog Light to HID but I notice when I start the car with the lights on auto one of the fog comes on once I turn off the fog and put it on they both comes on, any idea Thanks
Old 04-11-16, 12:00 PM
xRYD3Rx
xRYD3Rx's Avatar
Definitely not normal ! What HIDs you installed? Also whats the bulb size?
Which side that does not turn on put it on the other side and the working one on the other side. That way we can figure out if its the bulb or if its the wiring of the car. I think its the bulb though.
Old 04-11-16, 12:01 PM
shardul
shardul's Avatar
Try to flip the connections if that does not work you may need a different brand of ballast
Old 04-11-16, 12:04 PM
xRYD3Rx
xRYD3Rx's Avatar
I dont think its the connections because his saying it turns on when he turns the fog switch off and on. Im assuming its the bulb that may be the problem here.
Old 04-11-16, 12:44 PM
mikesd1980
mikesd1980's Avatar
Where did you get HID's from? Some HID sets will do that. Eventually the ballast or headlight will go. If I was you I would look at getting ballast and light replaced. I would take the fogs out of auto and turn them on after the car have been started. That will help it last. I experienced this with headlights and foglights on my infiniti m35. I eventually switched to LED headlights and fogs. That didn't happen again.
Old 04-11-16, 01:40 PM
frotiss
frotiss's Avatar
Thanks for your help it was some used Ballast I had in a box not using
Old 04-11-16, 01:55 PM
mrkwinning
mrkwinning's Avatar
Sounds like you need a relay harness. Extremely cheap. You can get one form DDM Tuning for like $11 or so. Basically what is happening is that there isn't enough power when the car starts up so there is uneven voltage.
Guarantee this will solve your problem since I've had this happen to 2 of my vehicles.
Old 04-11-16, 02:34 PM
mrpartsman
mrpartsman's Avatar
that sounds like a ballast problem, you should switch it to new and run a relay with the harness so it wont draw so much current out of it, or the best way is LED fogs if I were you look so much nicer.
Old 04-11-16, 02:38 PM
frotiss
frotiss's Avatar
Thanks for the help, can anyone suggest some nice LED as bright and clear to match the Headlight.
Old 04-11-16, 04:02 PM
mrkwinning
mrkwinning's Avatar
Morimoto's
http://www.ebay.com/itm/Morimoto-XB-...NWThrO&vxp=mtr
Old 04-11-16, 04:16 PM
frotiss
frotiss's Avatar
Thanks but I prefer a kit just to change the bulb not the entire light
Old 04-11-16, 04:35 PM
mrkwinning
mrkwinning's Avatar
Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H11 H8 LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H11 H8 LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive
Old 04-11-16, 06:14 PM
xRYD3Rx
xRYD3Rx's Avatar
http://www.ebay.com/itm/New-PHILIPS-...ZW0n7Y&vxp=mtr
You won't be disappointed this are some good stuff!
kitsune
IS F (2008-2014)
10-05-16 08:42 AM
AlohaCab
CT 200h Model (2011-2017)
02-13-13 03:27 PM
jvsc300
SC- 1st Gen (1992-2000)
22
01-11-09 07:25 AM
isdjmark
10-27-07 02:37 PM
Quick Reply: Fog Lights
