Driver side mirror motor replacement
Old 02-13-17, 03:12 PM
Toyboy300
Toyboy300's Avatar
Default Driver side mirror motor replacement
Some MF broke my mirror on the driver door. Question is...can the motor assembly in the mirror housing be replaced? The white part that swivels is broken and I'll need to replace that with the mirror itself.
Thanks for the help!
Attached Thumbnails Driver side mirror motor replacement-20170212_104334.jpg   Driver side mirror motor replacement-20170212_105047.jpg
Old 02-13-17, 08:16 PM
lexo98
lexo98's Avatar
Good luck bro. Same thing happened to me twice in 3 weeks! Changing that motor was a ***** because I couldn't get the mirror to pop back in place. Also I cracked on mirror trying to do that. Also I don't think there is a way to route the motor wires through the mirror housing into the door panel without cutting them. I got tired of trying to figure it out and just cut and spliced them back together. If I could have found a complete mirror painted the color of my car I would have done that
Old 02-14-17, 10:05 AM
Toyboy300
Toyboy300's Avatar
Mahalo for confirming. I don't know how big the connector is but splicing seems like the only option.
Being in Hawaii, I don't need the heating feature. If I could figure out what wires to bypass it would make the job easier.
Old 02-14-17, 07:31 PM
lexo98
lexo98's Avatar
when you unscrew the motor and pull the wires out a bit you will see a point where the wires are covered in foam. The foam is covering wire connectors. Peel off the foam and unplug them. Try to route the connectors out of the mirror housing. You will see one connector is a little too big. At least to me it was. Also the back of the mirror has a plug that can be undone. Just look at it closely. I should have taken pics
Toyboy300 (02-16-17)
Old 02-15-17, 10:42 AM
sakataj
sakataj's Avatar
he can find pics in the steps of this DIY
https://www.clublexus.com/forums/gs-...n-signals.html
i think the 2nd time i did these i just cut them and soldered them
also OP yes the internals can be replaced but so much easier to install a whole replacement side mirror
Old 02-15-17, 04:18 PM
lexo98
lexo98's Avatar
i was going to post the link to your DIY the other day and the link was dead for me. Thanks!
sakataj (02-21-17)
maxx430
10-20-14 01:23 PM
69charger
09-10-13 06:45 PM
irokdastar
04-21-11 01:56 PM
Poqman
07-28-10 09:15 AM
JCW
02-26-06 05:54 PM
Quick Reply: Driver side mirror motor replacement
