hesitation problem
I need help with my gs300 1998. Cluster turns black after few seconds when all icons come up when starting up the car. Check engine light pops on as well as all the icons for suspension. Then icons turn off. The bell noise also had a drifferent tone after a few tries of turning the car on . It turns over then dies. After that you can turn the key all the way over and nothing will happen. Heeelllpp me
I've driven every year GS400/430 except an '04. And the 400's are awesome, I love my '99. my Aunt has an '01, and it does this and there's nothing wrong with her car. If you kick it hard like at least half throttle it bogs down and then all the power comes in at once and the tires spin. I driven '02s with the same hesitation. The 03's do it less than the '01-02.. I have an '05 and it doesn't have his problem, the car is a beast off the line because the 430 has more torque than the 400. (Maybe in 2005, they address all the little nannies out of the car) I'm happy with my 2005 GS430 with no hesitation but the GS400 is better throttle response of course.
ok so what will cause the hesitation when pulling out into traffic, i step on the pedal and it goes to mid point then the car catches and it goes , i have replace the TPS and the MAF sensor i also clean the intake upper and lower no more carbon in the intake manifold the car starts up fine and ia at 475 idle also replace the PCV valve. any one has an input on this headache. at this point i am ready to put some c4 in the the and hit the trigger. need some help.
My early 98 GS400 will do it coming out of a corner IF I run low octane fuel (only experimented with a couple times). So knock will cause a big hesitation as it abruptly yanks out a ton of timing.
ok thanks. now i have a issue with the pedal position connection someone be for me had replace of try to fix the connection and now i am trying to figure out how to put the wire in the correct place so i can get some throttle response.
awzdusty
04-20-20 05:31 PM
CheVelleSS
Performance & Maintenance
12-14-13 03:30 PM
