Question....GS300 Coolant Temp sensor for gauge cluster
After talking to Sewell and my local dealership. I figured out the part number (83420-30020) for the coolant temp sensor/sending unit that sends its signal to the gauge cluster.
Now my question is.....what does the plug look like? (i no longer have my stock engine/harness so i cant look at it).
Does anyone have a picture of the plug that goes into the sensor/sending unit?
I will upload some pictures of the sensor/sending unit that i am talking about shortly.
If you are looking for the sensor that the gauge takes its readings from, it is called the "sender gauge" or the "coolant sender gauge". It has just 1 pin on the connector plug. Not 2 pins on the plug like the typical coolant temperature sensor. You can type "gs300 coolant sender gauge" on ebay and they are around 13$ each.
BluesImage
05-03-14 08:51 PM
GreenUCF20
08-19-12 04:46 PM
8342030020, cluster, coolant, ect, gauge, gs300, leus, lexus, location, questiongs300, sensor, switch, temp, temperature, water
