All control functions stopped working while driving
While driving home from work today all my control functions stops working. All the steering wheel buttons, radio functions, and the center display screen all froze up. It wasn't until I restarted to car for everything to work again. Anyone have a clue what all that components have in common?
I'm pretty sure that system is separate from the engine and safety systems. If the brakes and/or steering ever stop working, have them carry the car to the dealer on a flatbed.
was it a very cold day?
any drastic temp changes that could work a connection loose?
-and was it just the radio/nav, display, correct, or drive line type failure. (power steering/power brakes, loss of power.)
System crash with aftermarket navigation
I had a similar system crash with my aftermarket audio/navigation system. I was zooming out on the map while on cruise control when the steering wheel audio/phone buttons and center console audio buttons stopped responding and the navigation screen didn't update. The only way to fix it was to pull over the side of the road and restart the car.
This happened on an aftermarket system but I wouldn't expect the factory nav to be immune to software failures either.
Poppa
Controls stopped working
all the radio controls stopped working then I noticed that I could not switch from Audio to Navigation I could not switch anything on or off or change volume settings. I am driving an 2015 ES 350 pretty well loaded. While at a light I shut off the engine and restarted the car and everything started working normally.
This seems to be an ongoing issue with some 2015 Lexus models. My 2015 LS was delivered to me with a nav system that would do this routinely, they had to replace the nav headunit and then ultimately the navigation SD card. I have a business partner with a 2015 GS350 and he has had some sporadic similar problems but they haven't been as bad as mine were to where he's had them look at it.
If it continues you should definitely bring it to the dealer.
had this happen only once so far in 7 months of ownership. restarted car all functions returned to normal. there was so little talk of this i thought i was the only one until now. sounds like some software going bonkers....
ClaytonW
01-27-16 12:27 PM
