AC Problem: Air Mix Door Position Sensor
After taking my car to the shop, we found the problem. We first had the freon drained and new put in to no avail. Test were run and this is what I got : "Air Mix Door Position Sensor Signal Does not Change". The shop I was at did not want to work on it. Said that the part that needs to be replaced is behind the dash and everything needs to be taken apart.
Anyone have this done or any info on it?
foreste1
GX - 1st Gen (2004-2009)
05-11-17 05:58 AM
