ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Wiper Blade winter/summer mode
Old 03-29-13, 08:49 AM
scuchaofan
scuchaofan's Avatar
Unhappy Wiper Blade winter/summer mode
Hi all,
I have a 07 ES 350. Several days ago, I went to auto car wash without turning off the auto wiper blade. When I came out, I saw the wiper blades were higher than before. Then I loosen the nuts, and put them a little lower trying to make them back to original position.
But now I realized that it does have Summer/Winter mode.
Is there any way to make sure which mode is it now?
Should I pull down the blade after starting the engine, or before?
Thanks a lot for any help.
Old 03-29-13, 09:14 AM
LexBob2
LexBob2's Avatar
Originally Posted by scuchaofan
Hi all,
In the owners manual there are instructons with a picture or two (if I remember correctly) on how to put them in the summer or winter positions. It seems kind of wierd the first time you change the positions.
Old 03-29-13, 09:45 AM
scuchaofan
scuchaofan's Avatar
Yep, I saw the instructions which have two pictures.
But when I pulled the wiper blades down, they couldn't go any further than high position.
Any thing I'm wrong with it?
Old 03-29-13, 09:53 AM
scuchaofan
scuchaofan's Avatar
Old 03-29-13, 10:09 AM
LexBob2
LexBob2's Avatar
It takes a bit of force but it goes into the position. To me that's what seemed kind of scary the first time. I was sure I'd break it.
Old 03-29-13, 10:53 AM
nevernu
nevernu's Avatar
Hi all,
since u adjusted them i now would turn the car on and move the blades to mid position and turn car off. from there u can try to move it up or down manually and see what they are set to, and readjust from there.
Old 03-29-13, 12:04 PM
ThumperPup
ThumperPup's Avatar
wow ok another thing i miseed in the ownere manual hmm going to look at summer winter mode wiper blades wow
Old 03-29-13, 04:44 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Lot's of threads written about this. Here's just a couple:
https://www.clublexus.com/forums/es3...ay-wipers.html
https://www.clublexus.com/forums/es3...ches-hood.html
It's not really a summer/winter thing. It's there to allow you to pull the wipers up from the windshield base when washing the vehicle. If the wipers are in the lower position, they can't be pulled away from the windshield.
And just a word of advice to the OP, never mess with something unless you know exactly what your doing and have thought it through. In your case, since the wipers were in position before you went to the car wash, why would they have moved from that position? The car wash knew about the 2 positions, and moved them up to wash the windshield. how could you have reasoned that the nuts somehow came loose and the wiper blades got moved and then tightened themselves down again? And, shame on the car wash for not repositioning the wipers down to the correct position. But, yup, over the years, I've learned this lesson through making the same type of mistakes.
Lou
Old 03-29-13, 05:07 PM
LexBob2
LexBob2's Avatar
The winter setting is good for owners in cold climates where they get a lot of snow and ice. The up position prevents the blades from getting frozen/stuck in place from ice and snow build up.
Old 04-01-13, 07:26 AM
jcat_350
jcat_350's Avatar
And also puts the blade surface on the glass that's directly over the defroster vents
Old 04-01-13, 07:27 AM
donhellert
donhellert's Avatar
Thanks for this thread! I bought my used 2007 ES350 3 weeks back and I thought the wipers were a bit high. Now they are back to normal. Missed that one when perusing the manual.
Old 09-14-13, 02:18 PM
Lexi66
Lexi66's Avatar
Default Wiper blade winter and summer mode...
Question ... If you simply raise the blades to wash the windshield, does that start the problem?
Thanks Bob
gridlock13
12-01-22 12:15 AM
golferjack
RX - 4th Gen (2016-2022)
28
12-30-20 03:20 PM
86'ed
16
09-01-16 08:48 PM
johncoby
04-01-14 11:04 AM
lbintab
03-15-12 07:04 AM
Quick Reply: Wiper Blade winter/summer mode
