98+ cluster in 92~96 sc300
Old Oct 20, 2009 | 06:12 PM
YeA 2jZ's Avatar
YeA 2jZ
Originally Posted by TURBO819
I did about Four of them a while back. I cut all of the Plugs off of the 97 - 00 SC300 or SC400 and solder the wires to the 92 - 96 SC400 or SC400. There were about Three wire that had no match on the 92 - 96 SC400 or SC400 Wire harness. I made it so I could use the 97-00 Cluster or 92-96 Cluster Both could also be plugged in at the same time. I will Post a picture of the one I have later
SO you basically got the plugs from the 97+ cluster wire harness and by color matching you solder them into the 92-96 wire harness and still leaving the original plugs in did i understand you correct ??? This sounds very interesting if true
Old Oct 20, 2009 | 06:37 PM
TURBO819's Avatar
TURBO819
Your 100% correct
Old Oct 20, 2009 | 06:57 PM
YeA 2jZ's Avatar
YeA 2jZ
Your 100% correct
and cluster works properly without issues any random lights
Old Oct 21, 2009 | 10:51 AM
sc250tt's Avatar
sc250tt
I did the conversion on my 92 sc ..took about 30 mins to remove / install.. It looks 100 times better than the older cluster imo.
Old Oct 21, 2009 | 10:52 AM
UpInTheLex's Avatar
UpInTheLex
Do you have any pics of it sc250tt??
Old Oct 21, 2009 | 10:54 AM
sc250tt's Avatar
sc250tt
I have some on my computer at home. i will post them up later for those intrested.
Old Oct 21, 2009 | 11:29 AM
UpInTheLex's Avatar
UpInTheLex
Gated shifter cars do have gated shifter patterns on the dash.
5 speed auto cars have 5 indicator lights on the dash.
Old Oct 21, 2009 | 12:00 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I don't get whats supossed to look better?
the extra lcd screens? everything else looks identical.
the only thing usefull from a 98+ is the gated shifter and the steering wheel IMO.
Old Oct 21, 2009 | 12:02 PM
UpInTheLex's Avatar
UpInTheLex
The backgound lighting is cold cathode on the new style ones.
photo is from olt.
Old Oct 21, 2009 | 12:04 PM
YeA 2jZ's Avatar
YeA 2jZ
thats ur opinion but i think it looks cleaner and brighter then a pre 97 cluster i want to do this sc250tt post up pics i wanna see this
Old Oct 21, 2009 | 12:47 PM
Luxor's Avatar
Luxor
You have to see the cluster lit up in person to see the big difference between the old clusters and the new ones.
Old Oct 21, 2009 | 01:52 PM
99SC42's Avatar
99SC42
Yes there is a difference the 98+ look better than the older one not sure about 97
Old Oct 21, 2009 | 02:09 PM
UpInTheLex's Avatar
UpInTheLex
From what I've found the clusters are the same from 97+.
Since the 98+ sc400 is a 5 speed auto and the gated shifter they should have a gated looking shift indicator on the dash. But I'm not certain of that. If it does, the only downside would be it having a 5 speeds worth of indicator lights on the dash.
So then why not use a 98-99 sc300, they still have a 4 speed indicator, BUT...
You can't use a sc300 cluster with a sc400 because the tach will give false readings.
So seems like if you have a sc400, you're going to want a 97 cluster from an sc400.
Old Oct 21, 2009 | 07:03 PM
wheels 2's Avatar
wheels 2
I did this in my 92 sc back in may.Aliga asked me to post a thread about it but i never got around to it.I got the cluster and wiring harness for him.Only thing i wish it had was outside temp working.But i guess since my car is a 92 it didn't come with that sensor?But what would be cool is if you could hook up a sensor to get oil pressure to work where the outside temp was.
Old Oct 21, 2009 | 09:30 PM
YeA 2jZ's Avatar
YeA 2jZ
how much was it to get done by Aliga ?
