Toyota Lease turn in question
My lease on my 2006 4runner will be coming due eventually and I have a question. Normally I turn in the trucks and walk away not worrying about its condition, tires or etc, but this time is different. I have had to extend my lease once already and maybe one more time in hopes the 2010 will arrive soon and my tires will be in rough shape. As a toyota lease, what will they do if the tires are completely worn out? Is it my responsibility for the cost of new tires or what?
Thanks,
Brandon
Thanks,
Brandon
As OP noted, they are quite generous regarding condition of car at turn-in. But worn tires will be an obvious problem.
I probably could have glanced at my lease although its probably in barely legible fine print
I will see how the next few months goes, and if necessary buy some el cheapo's before turning it in.
Thanks,
B
I just turned in our RX today and tires was one of the first things they checked.
The specific conditions of your lease contract, of course, may set a different limit.....that, you'll have to check on yourself. And barring the use of tread-wear indicators, other state laws, or lease-contract clauses, an old tried-and-true method of determining safe minimum-tread depth is to take a Lincoln penny and hold it upside-down in the tread groove. If you can see the top of Lincoln's head, then get to the tire shop.
And, last, with an AWD /4WD vehicle like the 4Runner, tire replacement is made more critical by the AWD system. Newer 4Runners, unlike older ones, have a center differential, and, in auto (not locked) AWD mode, need all four tires to have close to the exact same wear and rotation speeds on them. The manufacturers of many AWD vehicles do not recommend replacing just one or two tires on the front or rear and leaving old ones on because the difference in rotation speeds will cause added wear and heat buildup in the center differential, shortening its life. You want all four tires, in an AWD vehicle, to be as closely matched as possible, bith in size/style and tread depth, too.
Thanks,
Brandon
Just make sure to have matched set of size/ratings as OEM tires. Don't worry about OEM brands originally installed, just pick the cheapest brand you can find.
at least on my m3, it states very clearly that by the time i return my car, it HAS to be on michelin ps2, same as the tires from factory, and has to be more than 2/32 or 3/32 i forgot. so they are very specific.
