I have a bad gas mileage, how about yours ??
Anything that I can do to increase my gas mileage? I have just changed the engine oil, transmission oil and air filter.
Does fuel injection cleansing and spark plug change ... can improve the gas mileage? Many thanks.
your probably gonna hear a lot of mixed reviews on the effects of fuel injector cleaner. I add a bottle of chevron fuel injector cleaner every time i change my oil, but i cant really tell the difference.
Hmm, that's about 12.5 mpg or so. I get about 15 to 16 mpg right now under my conditions (see my homepage below for more)
Would be interested to know how many kms you have on the odometer, what type of engine you have in your Harrier, the 2.2 or the 3.0 and if you have AWD or FWD?
Fuel injector cleaning and spark plug changing can improve gas mileage In addition check the following.
-tire pressure
-MAF sensor cleaned (I'll point you in the right direction if you want to know more)
-IACV cleaned (what is your RPM reading at idle?) (generally spray carb cleaner in a small hole in the throttle body, if you need to know more about this let me know and I'll point you in the right direction)
-Pull EFI fuse or disconnect negative battery pulled for a few minutes (to clear ECU). I generally recommend the latter the first time you do it as it appears to be more effective from my observations.
-in the case of an AWD and depending on the kms, good to change out the transfer case and rear differential fluids
-fresh coolant (having an old coolant leads to a hotter engine over time, increasing NOX emissions in the case of emissions tests and since exhaust passes through A/F sensors on one or both banks (depending on engine configuration) makes gas mileage less efficient. I like to add at least one bottle of Redline WaterWetter to the coolant and noticed on Redline's site they have a dealer in Hong Kong, http://www.redlineoil.com/dealers_in...=35&submit.y=5
-Less restrictive muffler
-alighnment and balance of tires
If you need any other help just let me know.
How do I know my car is AWD or FWD?
There is a emblem "3.0 FOUR", so I assume that's AWD, right?
Mine has 63000 kms on it.
My idle is around 600-700 rpm.
The temperature of my engine is below half on the gauge.
What is MAF and IACV?
Being 3.0, your engine is the 1MZFE that you would find in Canadian and U.S. markets.
Your idle is about right, we see 750 RPM as average, but in hotter months it can dip slightly and/or when MAF/IACV/air filter is dirty.
Your vehicle is still very young for its model year.
Cooling temperature is good if at or below middle line.
As far as AWD you should have it, but emblems can be deceptive.
So check underneath your vehicle and see if you have this outlined in blue, if so you have AWD.
I'll talk about MAF/IACV in next few posts.
First thing you want to check out is the MAF (Mass Air Flow Sensor). This is the location in my RX, but you will find it just after your airbox and it looks just like the one you see here. This little sensor basically measure the flow/temperature of air entering the engine to help in the calculation of the air/fuel ratio (a.k.a. to help deliver the right amount of fuel based on how much air is coming in).
Once you have it in your hand you should notice this, a red diode. One side is usually a little dirtier than the other. This is the second most likely cause of the infamous P0171 error (a check engine light error that is the most common affecting the RX300). The number 1 cause is just an abnormal air flow reading. What you want to do is clean it. Electrical contacts cleaner works well, but I happen to use due to easier availability computer keyboard cleaner. This is step 1.
It gets dirty mainly due to the fact that the way this and many other engines work is that they recirculate oil, moisture and other non-exhaust-byproducts of combustion via the camshafts through the PCV Valve (will get to that, too) and the crankshaft vent filter hose (a hose that hooks up to the air intake just in front of the MAF sensor). As you can imagine these byproducts can clog the IACV and thus cause reduced idle rpm among other things. What you need to do is locate the throttle body below and remove the two rubber hoses (they are accordion shaped and held in by two brackets) and you should see this.
THERE IS AN UPDATE TO THIS STARTING AT POST 42 OF THIS THREAD.
On the right side there is a small hole in the tube.
Another small trick that does the same thing, though not quite as effectively is to pull out (with the key of the ignition) the EFI fuse located here in your fusebox. Take it for at least a minute and then put back in and start up your vehicle. It might have a low idle at first but then should start to pick up. This is normal. Pulling the EFI fuse for a minute can also help reset any CEL (Check Engine Light) you may have, assuming it isn't something that is permantent such as a messed up part, bad sensor, etc, then the light will stay on.
