ok peeps, i did this with my poo-poo camera phone, so i apologize..neway ..I changed all my lights to led, installed my illuminated scuffplates, and changed my fogs out.
Allright since its up again I can update. These are the sizes/type of the bulbs: Low beam headlamp H11-55W
High beam headlamp 9005
Parking light 168
Front turn signal 992 (7440A)
Rear turn signal 7440
Tail light LED
Stop light LED
High mount stop light LED
Fog/Driving light 9006
License plate 168
Back up light 921
Front sidemarker 194
Rear sidemarker 194
Glove box 37
Front Dome light(3 bulbs inside)
194
Rear Dome light (2 inside) DE3175 also called "festoon" bulbs
for the dome lights it easier. for the front dome light there are screws hidden in the sunglass holder
after you take out the 2 screws there are 2 plastic fasteners that hold the rest in. you can pull those out
there are 3 bulbs(194) they will twist out
finished product..you dont see it here but bc the led's are so close to the lens you will actully see 3 bright dots of light within the lens..maybe not if you get refracted led's
the rear dome light is easy just use a special tool called a "credit card" or something like it, and pop off the lens. you will see two bulbs inside. They are called double ended or festoon bulbs or DE3175, 31millimeter(length) bulbs
finished
The LENS in the side doors are red OEM. the new ES350 has clear ones so i bought two of them to swap. THE PART # FOR THEM IS 81230-47010.
1st part of housing
2nd part of housing..it snaps on top of first part.
door light and illuminated scuff plate(i have sports pak so it was PnP)..sorry its blurry
changed fogs..
i think the car looks good at night when i walk up to it and it lights up..YEA!!
Omg sticky! finally someone changing the outside lights. I been tryin figure out how to do it. Thanks alot
edit: damn the screws are pretty tough to get to for those puddle lamps. I feel like I might break it if I push anymore, how did you get to all those screws? did you strain the mirror?
Beautiful! So there is technically a way to take out the mirror housing without removing the mirror. Thanks! Oh yeah, Gotta order those clear ES350 door lights.
