- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
****Official Wheel & Tire Fitment Guide for SC300/SC400****
A firm believer in beauty in simplicity.
I've contacted Volk and other places across the US and they have been pretty consistent with the offsets. Not sure if what you say will work. See i am going with Supra TT brakes thus my offset delima. Dag i have a lot of crap to order lol.
Have any pics of that kind of setup with offsets? Just curious.
It's likely that aftermarket wheels will need spigot rings to fit correctly on the SC's hubs. One of the Australian Soarer Club members suffered snapped wheel studs because the rings were missing. If you buy new wheels the spigot rings should be supplied, but are they there if you bought used wheels or a used car? They were certainly missing on my Soarer ......
I would guess that a "spigot" ring is better known as a hub centric ring on this side of the pond. Thanks for that info as well.
Gareth
Rim Brand and Type: Sparco NT
Rim Size f/r: 18x8.5 & 18x10
Rim Offset f/r: +45
Tire Size f/r: 235 (needs 245's) / 265 (needs 285's)
Suspension Setup: Height Ajustable Factory Air Bags
Comment On Ride: Also Electronically Ajustable
Fender Modifications: none
Any other comments:
Front high disc & rear normal disc to clear large calipers.
As you can see it needs bigger tyres on the rims!
Handling is very balanced and doesn't tramline due to the correct offsets, I track the car so that's more important than looks to me
Pictures:
Rim Brand and Type: Veilside Andrew Racing F
Rim Size f/r: 18x9.5 & 18x11
Rim Offset f/r: I forget...
Tire Size f/r: 275 / 295 (tire sponsor didn't make a wider tire at the time)
Suspension Setup: HKS Hipermax II Drag Coilovers
Comment On Ride: 32 way adjustable, smooth ride... way better than the TEIN HA's i used to have.
Fender Modifications: None.
Any other comments: 11" wide wheels in the rear will not fit w/o coilovers, at least not the way I have them set up (tried w/ Eibach + Tokico). When I originally made measurements and offset calculations, I went a bit more conservative in the front than I had wanted...
Pictures:
Here's an old shot:
Rim Brand and Type: Racing Hart C2 3 pieces
Rim Size f/r: 18 front and rear
Rim Offset f/r: i believe it is +50
Tire Size f/r: 225/40/18 front, 235/45/18 rear
Suspension Setup: OEM, but purchasing shocks and springs within the next 10 days
Comment On Ride: nothing much to say, but will update after suspension are installed.
Any other comments:
Picture: coming soon, most likely after i install the suspensions.
Pictures:
Here's an old shot:
Have any more pics? I am really curious to your offsets as well.
Rim Offset f/r: +45
Any other comments:
Pictures:
I said "no offence." I can't helpt it that most people unknownly buy poor fitting wheel that are super sunk and look like crap. That's why I'm here to guide people in the right way of doing these as far as wheels. Most people are clueless of offset or even if they know what it is choose weak offset and don't know any better. I"m just trying to stear people toward the right direction.
Ok, it's time for another episode of Being Openminded with Solshinobi. *que dinky music and Solshinobi walk to a closet and hangs up a robe and slippers and then turns to look in the direction of Nitekids*
What people like has to do with many factors man. It starts with perception. How you "perceive" things such as your life, your money, and other influences will direct your choices. What i'm saying is he might have chosen this set up for a particular reason. It might have suited him personally and that's what he liked.
Yeah we can all judge others but what does that really say about you man? Think about it cause the world would be pretty boring if everyone was exactly the same or had the same styles and tastes. Just keepin this short, simple and to the point.
Peace.
but as far as the wheel sitting the way it should to look optimal they are not familiar with. Thats why I am trying to help others on here to make it look like the way it should look.
If you read cyberdiamo's post, he states
You are right in that not many people has a full understanding of how offsets affect the wheel fitment. It is great that you can lend a hand but please be aware that not everyone will need (not necessarily want) the wheels to fit the way you personally like them to.
