Offset question
Old 03-23-03, 06:43 PM
4double0
4double0's Avatar
Default Offset question
Guys,
Will 19x9 fronts and 19x9.5 rears with a +37 offset work on a GS4 with l-tuned suspension? Also will this setup produce a nice wheel lip. I want the lip of my LD1s for the front and rear to resemble the LD1s in the attachment. If a +37 offset won't work, what offset should I get to produce the best looking lip for the LD1 wheel design? Please help!!!!!!!!!
thanks,
4double0
Old 03-25-03, 10:39 AM
Ag02M5
Ag02M5's Avatar
Default Re: Offset question
Originally posted by 4double0
Guys,
thanks,
4double0
+37 would be pretty aggressive for a 8.5" wheel. I would run +39 8.5" front and +39 9.5" rear.
There is alot of discussion on offset, use the search feature.
R
Old 03-25-03, 11:47 AM
JacobT
Guest
Posts: n/a
It will work. Look at this set up:
https://www.clublexus.com/gallery/sh...t=1&thecat=500
That's 19x19 front and 19x10 rear with +37 offset. With L-Tuned 1.25" drop, it works perfectly. If you're doing 20s then there may be some rubbing due to the extra inch in total diameter.
jwynn
SC- 1st Gen (1992-2000)
09-10-16 08:48 AM
MATEOGS
02-26-08 10:32 AM
u1923
02-21-06 05:20 PM
TNH
10-11-04 01:22 AM
beauphus
02-25-04 01:23 PM
Quick Reply: Offset question
