Mismatch offsets
Old Nov 21, 2005 | 05:55 AM
DASHOCKER's Avatar
DASHOCKER
Default Mismatch offsets
Hey guys. I have Axis Milanos staggered set up that i got from another member (see signiture). The fronts have opposite offsets from one another. One front wheel has a 35 offset and the other has a 45 offset. Is there anyting i can do to correct the difference, or do i have to scurry around for a new wheel? Axis no longer makes 19's in the Milanos now. I will have to search long and hard for a replacement if need be. Any suggestions?
Old Nov 21, 2005 | 11:16 AM
rominl's Avatar
rominl
exclusive matchup
put a 10mm spacer on the 45mm side to match with the other side?
Old Nov 21, 2005 | 12:32 PM
DASHOCKER's Avatar
DASHOCKER
Unhappy
I heard that is dangerous because that size spacer will not allow 3 turns to fasten the lug nuts and the wheel could come off while driving. I decided to bite the bullet and order 2 new fronts. They will be different from the back in that the new Milanos has 5 rivets instead of 4 between spokes, and has a bigger lip than its predecessor. It is now known as the Axis Milano Plus. I like to remove my 19's for the winter and slap on 17's. I learned my lesson and should buy rims that have posted offsets.
Old Nov 21, 2005 | 12:41 PM
PHML's Avatar
PHML
Master Thread Closer!!
Sean...
You need this one, right?
19x8.5 5x114.3 +35 26 2.25" Titanium Silver 5 spoke $380.00
http://www.spyeng.com/product_info.p...roducts_id=106
Pete
Old Nov 21, 2005 | 01:05 PM
DASHOCKER's Avatar
DASHOCKER
Originally Posted by PHML
Sean...
Pete
Pete you are the man. i just ordered from them and got the wheel I need brand new, and here is the kicker......He even threw in a new rear 19x9.5 for an additional 100 bucks. total 514 shipped with two new hub rings. I can replace one of the curb rashed rims in the rear with a new one. THANKS PETE!!!!!!!!!!!!!!
Old Nov 21, 2005 | 01:22 PM
rominl's Avatar
rominl
exclusive matchup
well you could have just gotten some longer studs and that would work already
but of course new wheels are better
Old Nov 21, 2005 | 03:14 PM
PHML's Avatar
PHML
Cool !!
Pete
Old Jan 5, 2006 | 05:29 PM
upstateGS4's Avatar
upstateGS4
threw in new hub rings? am i going to need those for my 20 inch milanos? they didnt mention about coming with anything except for the wheels and center caps...
Old Jan 5, 2006 | 10:39 PM
rominl's Avatar
rominl
exclusive matchup
most wheels are not hub centric and you should get the right hub rings
Old Jan 6, 2006 | 06:57 AM
upstateGS4's Avatar
upstateGS4
do you know where id go about getting a set of those for the wheels i mentioned to you that im gonna pick up...EXTREMELY apologetic for all these questions..never dealt with buyin big wheels before this is all new to me and i KNOW im startin to sound like a pita
Old Jan 6, 2006 | 08:42 AM
Neo's Avatar
Neo
The One
If you buy from a wheel shop, they should have them. Otherwise, contact D2 or TM Engineering.
Old Jan 6, 2006 | 09:00 AM
rominl's Avatar
rominl
exclusive matchup
i am not sure what's the hub of that wheels. a lot of times they are 73mm but again not 100%. the lexus hub is 60.1mm
so once you sure about that, you just get a ring that's 73mm (or whatever outside boundary) outside and 60.1mm inside
Old Jan 6, 2006 | 11:34 AM
GSXOTIC's Avatar
GSXOTIC
73/60.1 will do. I just bought another set yesterday for different wheels, so far those hubs work on Work, Weds, Amistad, and Trafficstar (Maya) wheels.
Old Jan 6, 2006 | 01:47 PM
upstateGS4's Avatar
upstateGS4
so these will work out for the 20inch axis milano too?
dboyz85
Aug 30, 2009 11:54 AM
MKIV98TT
Jun 29, 2007 04:51 PM
TurboSam
Feb 19, 2007 10:33 PM
